Hello everyone. I read this thread since 2011, when i started to build a G9. After just 6 years i finally managed to complete the project. Of course in the meantime i got married, got a baby, a new house and a new job.
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I built the G9 in just a month, long time ago, but i had a major problem that i wasn't able to solve. So i put it in a box. Until a week ago, when i decided to rebuild it with new boards.
My G9 was noisy. I followed all your suggestions, from trace cuts to GND tips. But there was no way to make it sound clear. It was like a random white or grey noise, but also variable like an old untuned radio. I thought it was something like a cracked copper track or some dirt shortcircuiting tracks.
So I cleaned the parts (also ECC82 tubes and their sockets) and installed the G9 in my rack just to see what it sounded like, what the problem really was. I was shocked when i found out that the unit was silent, clear and powerful. So what was going on?
No matter, it works. I just prepared the rack and installed the G9 in the final configuration.
Few hours later i got a bad hum noise caused by a bad soldering on the instrument jack. So i had to reopen and solder again the instrument wires under the mainboard. To do this i had to remove tubes and wires. Mounted again, turned on and ... hell! again that old grey noise.
I accurately cleaned all the tracks, the points, the sockets, all the contacts, all, all. Tried again: noisy.
Long story short: I swapped some tubes. Turned on: silent and clear.
It took forever to solve my problem because the only things i was sure about were trafos and tubes.
(N.B. i verified the sockets, the soldered pins and tried to gently move tubes while the unit was turned on = no problem here).
Now the question is: should i replace the tubes? Since i don't know why and what (or if) tube is defective, can it lead to some minor/inaudible problems?
Thank you all guys, this thread is a treasure. And finally, thak you Gyraf. Your contribution to the diy audio world is amazing. I can't be happier of my G9 and GSSL.
Have a nice WE!
Donatello.
