Midnightsun
Member
- Joined
- Aug 12, 2009
- Messages
- 15
The PCB boards from my early Lexicon 224XL are fully populated with spring contact sockets. Many of them have failed by loosing tension and therefore proper contact with the IC legs. That caused an error code party in the Larc. It's a known issue with the early 224X[L] production runs. Fixable but time consuming. I'm using gold plated turned pin /"tulip" IC sockets in exchange. I agree they can be a bit tight. Means, sometimes it can be a bit tricky when setting the ICs back in the sockets without bending a leg. I have the impression that some IC legs might be more "soft" or thin than others and bend more easily when pushed in the new socket. It helps to press the chip in with thumb and first finger on the sides/on the legs from the IC to guide and to stabilise the procedure a bit better
