chrissugar
H_A_M_P_T_O_N_E jfet amp modules
« on: July 20, 2004, 03:23:27 PM »
I saw that there is some interest in this so here are some pictures with the ones I made. The idea was to build these as some general purpose amp modules for DI, mic pre, makeup gain for compressors or summing buss amp.
I built 60 modules for various functions.
If you are interested in this PCB design I can post the file.
chrissugar
Here is one finished module from various angles
PCBs, fets, transistors and passives.
You can see that there is one PCB with sockets for the relevant passives and actives for matching components.
Finaly a little army of these jfetamp modules
and some more
chrissugar
Christian Mike Sugar
        CMS-LAB
rafafredd
« Reply #1 on: July 20, 2004, 03:28:32 PM »
You are a machine!!!
Greg
« Reply #2 on: July 20, 2004, 03:30:42 PM »
Nice !!!
Greg Stein
New Orleans, LA
Bauman
« Reply #3 on: July 20, 2004, 03:33:52 PM »
I had PM'd you dude  :grin:
cheers!
Fabio
_____________________
www.thediypill.com/store
[email protected]
« Reply #4 on: July 20, 2004, 03:34:00 PM »
Very nice! You are a busy man. I especially like the heatsink solution.
daArry
« Reply #5 on: July 20, 2004, 04:02:58 PM »
Nice, similar to my layout - heatsink too :wink:  I'm also using those same chunky wimas :thumb:....
tony dB
« Reply #6 on: July 20, 2004, 04:52:53 PM »
:shock:
and i thought i saw sometimes things a bit out of proportion  :green:
Why do you need al those channels for?
MASSIVE! aï  :thumb:
tdB
neilium
« Reply #7 on: July 20, 2004, 04:53:58 PM »
those are pretty cute. Nice work.
BODY MASSAGE!!! http://media.ebaumsworld.com/gijoebodymassage.mov (>1 meg download)
rafafredd
« Reply #8 on: July 20, 2004, 04:56:47 PM »
what is that beaultifull electrolytic cap? Panasonic FC?
clintrubber
« Reply #9 on: July 20, 2004, 06:14:07 PM »
Cool, over 40 units, at whatwassit dB a piece, ehhh..., you definitely got some amplification going on over there. :thumb:
fallout
« Reply #10 on: July 20, 2004, 07:14:07 PM »
Looks great! Can you post the artwork?
-Jay
adrianh
« Reply #11 on: July 20, 2004, 09:37:57 PM »
Great heatsink solution!
Artwork?????
Your layout and this layout looks very close?
See daArry posts:
http://www.groupdiy.com/index.php?topic=1097&start=15&sid=64a96f3188619c4d06f7465ebf6ee4c5
haima
« Reply #12 on: July 21, 2004, 10:12:59 AM »
i guess that's one way to get 10 bazilllion dB of gain...!!??!
well, i like this hamptone jfet amp as much as the next guy... but i can't imagine needing 60 of em!
they look great though chris
tubejay
« Reply #13 on: July 21, 2004, 10:40:20 AM »
Yeah, what are you going to do with all of those?!?!?   :?:  :?:
chrissugar
« Reply #14 on: July 21, 2004, 01:06:16 PM »
Before I answer all the questions here are the pictures for the solder and components side:
and you can download [right click and SAVE TARGET AS] from here the high resolution BMP to make the PCB:
http://www.geocities.com/chrissugar7/CMS-LAB-JFET-AMP-SOLDER.bmp
Sorry Fabio but I have no gerber files, I made the project with a freeware software, then captured it with a freeware printscreen capturing software. I know, it is a bit hardcore but all my small boards are made this way. :grin:
I have to say that I was surprised that DaArry's board is 80 percent like mine. My idea was to make it more like a plugin amp module like the 990 type opamps but in a diferent footprint.
Why do I need all these modules? Good question. I played with this circuit for long enough time and explored it and I can say that I was even more impressed by this than my 10 channels of N_E_V_E preamps or the A_P_I types because it is so simple, it sounds great and is very versatile. From a very clean classA to a coloured distortion box it can do everything. I tried it with Lundahl1636, 1538 and OEP and it can sound beautifull.
A module like this has aproximately 26 to 29 dB gain depending on the fets and resistor values you use.
So why I need all these modules? I have over 120 ouputs from my synthesizers/samplers, many from the harddisk recorder and also many from the digital fx boxes. But that is not the complete answer. I try to design my new toys in dual topology like the Millenias designed by Fred. For example tube and jfet amp modules, or bipolar amp and jfet amp modules. Enough variations. Just think about compressors, limiters, equalisers and you will find that 60 is not too much. :grin:
By the way you could ask why have I built 40 Millenia type opamps, and all those NTP, QuadEight and melcor and the answer would be the same.
 :grin:
chrissugar
        CMS-LAB
chrissugar
« Reply #15 on: July 21, 2004, 01:21:38 PM »
I remember people were concerned about problems with temperature variation. I put the soldering iron on the top of the heatsink up to the point when I cant keep my finger in the other end of the heatsink and watched the scope and the dB meter on the computer and the largest gain variation was 0.05dB. I think you don't have to worry because  you will never use it in such extreme situation.
I didn't use the 15k value because my fets were biased optimally at a diferent value. I had to select the fets from hundreds to find 60 that will bias correctly with the same resistor value. I used only the fets that gave an output DC value between 11.90 and 12.10 volts.
chrissugar
        CMS-LAB
Bear
« Reply #16 on: July 21, 2004, 03:20:27 PM »
Where would I come by that heat sink?  And can i get it in quantities smaller than 50?   :grin:
Bear
owel
« Reply #17 on: July 21, 2004, 03:34:02 PM »
Quote from: "Bear"
Bear
digikey has them. I'm using the same heatsink like that in my Neve PSU.
al_p
« Reply #18 on: July 22, 2004, 05:19:57 PM »
hey Chris
the link for the hi-res version doesn't seem to be working.
AL P.
rafafredd
« Reply #19 on: July 22, 2004, 05:21:07 PM »
copy and past the adress to your web browser. geocities does not link directly.
Last post July 12, 2004, 04:06:14 PM
by [email protected]
Last post September 20, 2004, 05:44:21 AM
by zebra50
Last post February 02, 2005, 10:33:26 PM
by aurt
Last post October 28, 2005, 12:10:46 PM
by PRR
