Because I received a lot of mails and PM about selecting JFETs for this module I will post what I wrote in my last mail to a member:
The easyest way to select fets is to power one Jfet amp module at 24V, and do not connect anything to it, (nothing to the input) just a multimeter and measure the DC between output and ground (output before the 10microfarad condenser, not after). It should be exactly 12volts. Probably you will have a different value so one option is to buy more jfets and find one that will give you exactly 12volts at out.
The second option is to replace the 15K resistor with a 10k in series with a 10k linear pot and adjust till you have 12volts at the output. Then disconect the 10k plus 10k pot and measure the total resistance.
You will put in that place a resistor equvalent with the measured value.
The third option is to do the same thing with the 1k8 resistor, you replace it with a 1k resistor in series with a 2k5 pot and adjust to find the right value for 12volts at output and then replace with the measured value.
The third option it is better than the second because it will not influence the gain of the module, only the DC biasing. If you whant to change amplification you can use the second option, it will influence at the same time the DC and gain.
chrissugar
***later correction:
I forgot that on my breadboard I had a 1M resistor for biasing the fet between the fet gate and ground. That fet is necessary for the measurement process.
Sorry, it was long ago.
