comment pleas, I know there're few mistake..... :roll:
http://img491.imageshack.us/img491/3283/headphoneamp4xm.jpg
Not sure I understand your question correctly--do you ask if it is OK to use the reference voltage set by R1/R3 for several opamps? If so, I'd say yes--but for big systems (e.g. a console above 8 channels) it is IMO wise to use dual supplies anyway.In a big sistem with many ICs the V reference got to the same for all ICs?
Yes--but I see what you are thinking. Note that you have an unbalanced input. To make an output transformer working you need to ground the unused side of the secondary. This forces the noninverting input of the input IC to zero volt, which is bad news for one half of your signal.If the signal came directly from the secondary of an output transformer, is C8 needed?
