[quote author="Samuel Groner"]* Q1 is upside-down,* Q2/Q4 are interchanged
* there is an error in the bias network for LED2 (one 4k7 wrong connected)
* R12 looks pointless
* the 47 pF RFI protection cap could/should be much larger, say 1 nF
Looks like a well-thought design though the current sources for the bias diodes are perhaps overkill. I've never tested the drive capability of an OPA2134, so I might be wrong.
Samuel[/quote]
yep to Q1 Q2 and Q2 and yep to the 4k7
looks like I was having an upside down sort of day
The pointless resistor of zero ohms ... (I used 0.1 cos the software doesn't like 0)
is for a gain adjustment if needed ...
this may require other component choices
and the design also includes an 8 ohm option where extra diodes are used to help current limit.
I think I have show a bit of a hybrid of high and low headphone options
sorry ... I was rushed
1 nF for RFI protection
ok I'll keep that in mind :thumb:
" ... the current sources for the bias diodes are perhaps overkill. "
Yes I think so too but it is that feature that prompted me to look at it and included it here and at the Factory.
It was just another and different slant on a fairly typical idea.
thanks heaps for you time
I'll fix asap
I've had an edit
http://www.diyfactory.com/projects/headphoneamp/HPamp01.pdf
the one above is still there (/HPamp_01.pdf)
and the full page will be at
http://www.diyfactory.com/projects/headphoneamp/headphoneamp_2.htm
when I'm done
DON'T look at it yet cos I'm not finished and it's all crap so far
