G
Guest
Guest
I am just putting a few modules together to to do the following (thanks to Peter P and others for the help):
Original Green Meanie 31267
Into Gyraf Pultec Filter Boards
Through Fabio BA283 output into Carnhill LO1166
Some of this stuff is waay over my head - but I have done my reading and tried to make sense of it all
I have hooked up the bits, soldered and de-soldered
31267 is configured for 10k:600R
+ in into Pin 2
Pins 3/4 joined
- in into Pin 5
Pin 6 ground
Pins 7 and 8 joined to + out
Pins 9 and 10 joined to ground
The LO1166 is configured for 600:600
Now doing the reading...
31267 in that configuration gives a 12db loss
The LO1166 gives a 1db loss
The filter circuit gives a 18-20db loss
So that makes a 31db - 32db loss
The BA283 output stage can give a 15db gain
But with the following resistors added to RGx it can be adjusted:
1k5...18db
1k2...20db
470...25db
220...30db
110...35db
Can somebody be a darling and give me a few ideas on who to fine tune the db ratings to give somethign a bit more precise in the 30-35db range?
or is it not worth it - set it to 35db and then forget it?
+ in into Pin 2
Pins 3/4 joined
- in into Pin 5
Pin 6 ground
1k5...18db
1k2...20db
470...25db
220...30db
110...35db
