2N3055 vs 2N3055H
« on: August 24, 2004, 05:18:38 PM »
what's the H stand for on the 2N3055H Motorola transistor? Comparing 2N3055 with 2N3055H :?:  :?:
bluebird
2N3055 vs 2N3055H
« Reply #1 on: August 24, 2004, 05:39:17 PM »
Hemi.....
Gus
2N3055 vs 2N3055H
« Reply #2 on: August 24, 2004, 05:51:01 PM »
I forget what the H stands for: however mot 2n3055H are good 3055s.
  Remember 3055 are often transistors that did not meet higher specs of different transistor numbers.  A 3055 can have different dies and masking all they have to do is meet the min specs of the 3055. Cut some open I have, people open tubes I cut open batterys transistors etc trying to understand what the differences are.
  IIRC at the old place someone did some testing and found mot 3055s to sound the best in the neve circuit.
   If i was to build a neve circuit with the 3055 I would try a MJ15003 instead.
NewYorkDave
2N3055 vs 2N3055H
« Reply #3 on: August 24, 2004, 08:20:19 PM »
The "H" stands for Hometaxial.
It has a larger SOA (Safe Operating Area) than Epitaxial-process devices, at the cost of a lower ft (bandwidth, basically). So, in plain English, what you have is a heavier-duty 2N3055.
2N3055 vs 2N3055H
« Reply #4 on: August 24, 2004, 10:15:09 PM »
Quote from: "NewYorkDave"
I think you made that up, Dave.   :green:  :green:  :green:
Seth
The definition of insanity: "Hey, this thing could be really cool - if I had the money to fix it up, which I don't, but if I did it could be really cool - if I had the time, which I don't, but
Last post July 06, 2005, 03:12:52 AM
by
Last post December 05, 2008, 02:30:49 AM
by Whoops
Last post September 06, 2009, 02:40:55 AM
by analag
Last post June 24, 2010, 11:35:54 AM
by JohnRoberts
