jdbakker
Update Mar 7 2007:
The PCB panels for the mic pre/ADC/VU channel strips are in:
Update Nov 18 2006:
Just finished the ADC-board, based on the Cirrus CS5381. Schematics are available for the converter and its power regulator; the board layout and BOM are here. See downthread for a design description.
Original post as of Nov 08 2006:
[here goes...]
Hi all,
For the past few months I've been working on and off on the design of a portable digital multi-track recorder. I've finally gotten to the stage that I have nailed most details down (down to which switches I should use), and I'd like to start presenting the modules one by one as they get finished.
The first module is a PGA2500-based microphone pre with a relay-switchable 100Hz HPF. The meat of the module is here, with the power supply here. For those who care, the component placement for the 2.5x5in PCB is here.
The design closely follows the PGA2500EVM, with the exception that I substituted NPO and polyethylene capacitors for the X7Rs recommended by TI. The phantom coupling electrolytics are Elna Silmic II's, all other signal path caps are Epcos polypropylene. Supply decoupling electrolytics are Panasonic FM (which I really like in my Greens, BTW), the 100n decoupling caps are 1206 NPO. The values for the HPF give a two-pole Bessel rolloff which sounds nice enough on the breadboard, although I may end up subbing the filter that PeterC uses in the Green. Note that the usual EMI-protection and phantom injection is handled on another board and is thus not shown in these schematics.
The next module I'm working on is a stereo ADC based on the Cirrus CS5381, with stuffing options for either direct DC-coupled in from the mic pre or a diff amp level shifter. The latter has a bit less noise, but I need to experiment to see whether I think the PGA2500 at zero offset + one extra op-amp stage sounds better or worse than the direct coupled scenario.
After that I have a full-digital peak/level meter scheduled, fed by the ADC output. Final steps are the hard disk interface and the VCXO with optional OCXO locking, but since I'm mostly a digital guy those should be easier to get done.
I do have different input options planned; I've already got a Greenish mic pre design done, and am working on a transformer coupled DOA version and a discrete direct-coupled pre. More on that later!
Questions ? Comments ? Derisions ?
JDB.
[thanks to Rochey for the support for the TI parts - definitely a useful resource to have here]
![](https://proxy.imagearchive.com/84f/84f3d05fcba5f65197e31849828a1666.jpg)
Update Nov 18 2006:
[here goes...]
Hi all,
JDB.
