What size fuse would I need if I'm hooking up 8ch Green Pre
ENS Audio
USA
Hello, I have the 15v Green Pre PSU and so I want to double check to see if I need anything higher than a 250mA fuse for an 8 ch Green Pre and for the Voltage rating....I do live in the US so without refering to my notes...would the voltage be 250v for the US???
Also, I will be using an IEC type connector w/fuse insert which brings me to my other question...would I need an additional fuse/holder connected to the "netural" wire of the mains wires???
Your comments and suggestions are very much appreciated,
No.
You need >125V, but you will probably find only 30V and 250V fuses. The 30V are for cars, and don't come as small as 250mA.
No. Outside your box, a Neutral fuse is ILLEGAL. Inside a correctly wired box, a white-wire fuse is pointless as long as the black is fused.
