electrichild
amek m2500 eq schematics...
« on: August 19, 2008, 11:34:32 AM »
I'm planning to make an EQ based on the amek m2500 eq section. On the schematics I find on the forum there aren't the original bell/shelf switches I would implement...Adding resistors and switches in the HF and LF path between R6/C5 and R45/C20 will affect the curve of Q pots?
Which values are right?
Respect
Electrichild
http://www.gyraf.dk/schematics/amek_m2500_eq.gif
jdbakker
« Reply #1 on: August 19, 2008, 12:08:28 PM »
Have you read this thread, and the older threads that its first post links to?
JDB.
electrichild
« Reply #2 on: August 19, 2008, 12:56:36 PM »
Quote from: "jdbakker"
JDB.
Thanks for reply.
Yes I read all posts inherent but it's not clear which are the values of the resistors. I imagine 220k would be ok for HF and greater for LF.
Have anybody really realized a good working eq based on that schematic?
12afael
« Reply #3 on: August 19, 2008, 08:05:56 PM »
the schematic from jakob site have the mods for the shef/bell sw.
IIRC you must make a shortcircuit in R137 (one half of the 50 rev log) and add a 1M resistor between r144(pot) and R50.
I have some schematics for LTspice if you want to play :razz:
cheers
Rafael
heavy metal is the law!!!
electrichild
« Reply #4 on: August 20, 2008, 02:47:22 AM »
Quote from: "12afael"
LTspice? What's?
jdbakker
« Reply #5 on: August 20, 2008, 04:50:49 AM »
I'd be interested!
Quote from: "electrichild"
LTspice? What's?
Linear Technology's free SPICE-based circuit simulator. you can download it from their site.
JDB.
electrichild
« Reply #6 on: August 20, 2008, 05:55:54 AM »
Very cool!
12afael
« Reply #7 on: August 21, 2008, 01:07:44 AM »
here are the simulation files and some models needed for the simulation. the models IIRC were from the yahoo ltspice group.
http://www.twin-x.com/groupdiy/albums/userpics/amek2500_nemek_Harrisonfilter.zip
Enjoy :razz:
Rafael
electrichild
« Reply #8 on: August 25, 2008, 07:57:47 AM »
About decoupling caps for the amek m2500 circuit of this topic
are C22-23 on schems 1uF 35V tantalum right?
Can I change the C4 39NF cap (hard to find) with 4 X 10NF in parallel?
Any suggestions?
Thankz again
12afael
« Reply #9 on: August 25, 2008, 02:40:15 PM »
tantalium or a small esr cap should do the work, 1uF film should work too.
I also put a small film cap in the power pins of each tl074.
39nF shouldn´t be so hard to find, but yes, you can use four 10nF in parallel.
Last post November 29, 2007, 01:09:23 PM
by tonebucket
Last post September 09, 2008, 03:23:43 AM
by electrichild
Last post July 04, 2019, 08:12:42 AM
by ilfungo
Last post September 08, 2019, 07:53:11 AM
by ilfungo
