Toggle switches used in Summit units, do you know the model?
Val_r
Naples, Italy.
Looking for a replacement.
Do you have the ref. # of mouser catalog (if they stock this part)?
Thank you in advance.
Respect,
Val
Hey Val,
I needed something similar for the LCR assign of my 24 channel summing buss. At work we have a few of the Summit leveling compressors and I had to repair one; the switches are  basically a DPDT with gold contacts. You can get these which are pretty similar on mouser:
Mouser #: 633-M2022B2B1G01-RO
Mfr. #: M2022B2B1G01-RO
Desc.: Toggle Switches ON-NONE-ON
RoHS: RoHS Compliant
http://www.mouser.com/Search/ProductDetail.aspx?R=M2022B2B1G01-ROvirtualkey63300000virtualkey633-M2022B2B1G01-RO
I'm not sure if you need the ON-ON or ON-FF-ON but I think mouser has those too..
They are the same big tiggle format.
Cheers.
Cheers.
Hi Mac,
Thanks for the reply!
From the datasheet I see that this item is miniature toggle, while I need big toggles, ON-ON.
Just for a reference, here is the pic:
Hope this makes sense.
From the catalog, I didn't see NKK switches have a big toggle version.
Any other option?
Thank you in advance,
Val
