Brian Roth
Nagra switches....I KNEW I had seen that switch design somewhere!
Bri
Bri
Given measurements I could make a batch of these.
Y'all just need to decide on a switch to fit. Or maybe there needs to be 3 different models?
I might even take few myself, these are supercool fittings;-)
Cheers, V
Inside it's probably 1/4-40 UNS (6.35) which is a standard for all mini toggle switchesY'all just need to decide on a switch to fit. Or maybe there needs to be 3 different models?
I guess it would be possible to reverse-engineer the measurements. I'm guessing the mounting hole in the fascia is 12.7 (1/2inch) and the switch is very likely 6.35mm (1/4inch) as pointed out by Zamproject. That would make the largest diameter 14mm? Depth would be defined by the length of the toggle lever, they come in a few sizes, and width/length of the cutout by the dimensions of same lever (1/8inch? 3mm?)
They look like they're anodized, which opens up a world of funky colouring options. How about a red and a black one to supplement the grey?
I do have extensive machining capabilities (and strong industrial connections).
Just thought I'd chime in, since somebody asked for a lathe. Mine is currently winding output transformers, one of the many tricks it does...
