7 pin XLR connectors
Gus
n
I just looked at alot of G7 posts and did not find a source of 7 PIN xlr connectors in the states.
In the USA what companys have the best prices on good 7 pin connectors? Mouser carrys up to 6 pin.
FWIW this is for a few china microphone rebuilds to a tube circuit. I don't like the royer 5 pin xlr method. If I build a body I often use Amphenols rated at 300VDC.
Hi Gus,
What is the issue with only having 5 pins? Is it that the -ves for the heater and B+ must be combined, and no separate polarisation voltage, or am I missing something here?
so for example something like this....
1, 2: Audio hot & cold
3 B+
4 heater +
5 0V
Screen = ground
I have several old tube mics now with just 4: B+ heater AC and ground connections!
Stewart
pattern control and proper shielding using the shield to carry ground currents is not a good way to wire a microphone.
Markertek is pretty good with connectors. They've done some special orders for me in the past--problem free.
You might try redco as well.
Tom
[quote author="Gus"]I just looked at alot of G7 posts and did not find a source of 7 PIN xlr connectors in the states.
FWIW this is for a few china microphone rebuilds to a tube circuit. I don't like the royer 5 pin xlr method. If I build a body I often use Amphenols rated at 300VDC.[/quote]
Allied:
http://www.alliedelec.com/
search part description xlr 7, they have both cable and chassis, gold contacts also.
Here are a few places I have found
http://www.electronicplus.com/content/ProductPage.asp?lname=audio&maincat=aco&subcat=ax1
http://www.audiogear.com/Neutrik7PinXLR.html
http://www.atlast.com/catalog/c30_p1.html
I can get Neutrik 7 pins to any U.S. folks that are wanting them ( from The Place Of My Day Gig ) Some look cheaper than the Amps at Digikey...
NC7FX: $6.59
NC7MX: $4.79
NC7FD-L-1: $10.75
NC7MD-L-1: $8.05
I am getting some for my G7s and can make it a group order if anybody's interested.
Steve
I'm sure you can get the 7pin amphenol at digikey...
I think chuck posted the links above...
Gil
you can get them in north america at:
http://www.btx.com/Categories.aspx?Category=f446fa1c-c2de-484a-b4c3-e8352b2feb51
or
:http://www.btx.com/
UP because I'm wondering what my choices are for replacing an XLR 3pin male connector in an existing microphone (say an MXL 2001) with a 5 or 7 pin connector?
Do I have to buy a $16 Switchcraft panel mount connector just to get something with a set screw?
Yes, you do need to get the Switchcraft if you need to have an insert with a set screw. Neutrik connectors don't have this feature which makes them useless for the connector in the base of the mike. Here is a place I found the Switchcraft fairly cheaply. The silver contact model is $10.19 and they actually have them in stock. Gold is a couple of bucks more.
Note that this insert is slightly shorter than the Alctron 7 pin male insert so the engaging hole needs to be in a different position. Otherwise, they seem to work nicely and interchangeably with the Alctrons (and I would assume the Neutriks also).
Thank you! One more question: Does it have to be a panel mount, or can I steal the same part from just a regular 5 pin XLR male cable end?
