For contacts just PM me, thanks Read all this post for other my products and infos before ordering, please.
DOA'S - DISCRETE OPAMPSAPP14GE very low noise germanium discrete operational amplifier --> available APP14GE is a germanium DOA that I have developed starting from my MA1 germanium pre. It's a new DOA so it's not a clone of another one. I have designed it both for line and preamp stages.
APP14GE uses both a germanium transistor and some silicon transistors.
The germanium transistor is placed on the best point to make sound. As my MA1 preamp, APP14GE, has a warm vintage germanium sound. BTW it can use some different germanium transistors inside for getting different colors from.
Kits came with docs with assembly manual.
Kitset version prices with the NOS (new old stock) AF106 germanium transistor :
-15 euros pc for 1 to 3 pcs.
-12.5 euros pc for 4 to 10 pcs
-11.5 euros pc for 11 to 50 pcs
S&H and paypal fees excluded.
Kitset version prices with the NOS AF127 germanium transistor :
- 15.5 euro per pc for 1 pc
- 15 euro per pc for 2 pcs
- 14.5 euro per pc for 3 to 6 pcs.
- 14 euro per pc for > 6 pcs.
all these prices are S&H and PayPal fees excluded.
PCB's only prices:
- 6 euro per pc for 1 pc
- 5.5 euro per pc for 2 pcs
- 5 euro per pc for 3 to 6 pcs.
- 4.5 euro per pc for > 6 pcs.
APP992high performances FET input discrete operational amplifier.--> available main features:
- ultra low noise (1nV/rt Hz)
- very high slew rate (75 V/uS)
- high class A operation
- drive 75 ohm
- can be powered from +-14V to +-25V , so it can use +-16V, +-18V , +-24V of power supply.
- very stable on unity gain. assembled version prices :
40 euros pc for 1 pc.
32 euros pc for 2 to 10 pcs
30 euros pc for 11 to 50 pcsS&H and paypal fees excluded.kitset version prices :
13 euros pc for 4 to 10 pcs
12 euros pc for 11 to 50 pcsS&H and paypal fees excluded.The docs include the assembly manual.
Support is at
http://groupdiy.com/index.php?topic=49711.0APP992 is not a version of the JE990 but a totally new DOA (my own design from my experience as electronic engineer).
I have designed it several years ago. It is a FET input DOA with modern design topology.
APP992 has a trasparent, neutral and clear sound with a FET mojo. Neutral but not cold.
It is used on many gears as eqs, compressors, pres,..etc...BTW is very used on Sontec eqs by many Diyers.
A few of comments on the web (not all):
http://www.gearslutz.com/board/9089219-post51.htmlhttp://groupdiy.com/index.php?topic=27972.msg618444#msg618444http://groupdiy.com/index.php?topic=48328.msg625302#msg625302http://groupdiy.com/index.php?topic=50733.msg643430#msg643430http://groupdiy.com/index.php?topic=55372.msg707043#msg707043http://groupdiy.com/index.php?topic=41430.msg705366#msg705366http://groupdiy.com/index.php?topic=54523.msg695933#msg695933MIC/DI PREAMPSAPP Studio Ing. MA1 germanium mic/di pre This mic pre uses both a germanium and some silicon transistors.
I have designed this gear to have the sound of germanium with the dynamic and the fast transients of my opamps. The germanium transistor has been placed on the best point to make sound.
MA1 an high performances gear with a lot of the warm that only a germanium transistor can do. It is designed for 500 rack chassis and so it works with dual 16V of power supply.
It has 64 dB of gain max.
MA1 can use several trasformers (some of Classicapi, Cinemag, Jensen, Altran and Lundhal),
PRICES:ASSEMBLED UNITS:- ask for prices, please
KITS:MEDIUM kit version:- 36 Euro per one pc plus S&H and paypal fees.
- 34 Euro per pc for 2 to 4 pcs plus S&H and paypal fees.
The kit includes:- chassis accessories: all screws, standoffs, bolts and washers.
- all resistors
- all semiconductors
- PCB
- all capacitors
are excluded the others components:
- chassis : front panel, L bracket, these ones are available at
www.frontpanels.de (contact me for them)
- the input and out transformers
- switches and switches' caps (the buttons on the front panel)
- potentiometer
- potentiometer's knob.
BASIC kit version:- 28 eur per one pc - 26 eur per pc per two pcs
- 25 eur per pc from 4 to 6 pcs
- 24.5 eur per pc from 9 to 15 pcs
plus S&H and paypal fees.The kit includes:- chassis accessories: all screws, standoffs, bolts and washers.
- PCB
- potentiometer
- all resistors
- all capacitors
PCB only:the PCB is double face FR4 professional with gold plated holes and connectors.
- 18 eur per one pc - 17 eur per pc per two pcs
plus S&H and paypal fees.the front panel and L bracket are available at
support thread: http://www.groupdiy.com/index.php?topic=49710.0 I/O board --> SOLD OUT! This high performances board can be used for many circuits to give them a balanced input and output (with makeup stage) when it is needed.
The IO Board is an input-output card, so it has an input section to unbalance signals from gears and a make-up stage to balance signals from unbalance sources. Moreover, the IO board has an high impendance FET buffer to interface the make-up stage to very high impedance sources if required. These very high performances input and out stage are both based on solid state technology and they can run with DOA's and/or IC opamps, so the customer can use many DOA's and IC opamps in the market.
Moreover, the out section has a zone for an output trasfomer to place easily it in 1U rack chassis, just using two screws. Can be used several trasformers (cinemag, jensen, classicapi) on it.
IO board can use all APP DOA's and many other DOA's as 2520, JE990 , JLM99....etc....
so you can choise the sound look basing on the DOA's (or IC opamps).
Just to note that it is also possible use the buffer plus the make-up stage as very high performance instrument amplifier with trasformerless or trasformer coupled out.
By the way it is possible use this board as line amplifier too, or both instrument and line amp.
I/O board has a new design for the input stage that does not use any electrolytic cap but only small 1uF polyester caps and a servo DC stage.
Moreover, a servo DC is present in the make-up stage too, to avoid any capacitor on input-output and in the nfb net.
This board was sold in a recent group buy with success so I would like to re-propose it to the market for who want a modern in-out interface. I have launched a support thread for the IO board here
http://www.groupdiy.com/index.php?topic=46320.0 schematic: http://home.teletu.it/APPSI/IO_board_eq2.pdf components list: http://home.teletu.it/APPSI/IO%20BOARD%20BOM.pdf
PRICES:
for 1 to 2 pcs = 18 euro pc plus S&H and paypal fees (3.5%)
for 3 to 4 pcs = 16 euro pc plus S&H and paypal fees (3.5%)
for 5 to 10 pcs = 14 euro pc plus S&H and paypal fees (3.5%)APP studio ing. "PICCOLO",
GAINCLONE LM3886 power amp card --> availablevery high performance module based on gainclone amplifier, PSU included in the same board, so you will buy amp + PSU inside the same board!
APP studio ing PICCOLO (PCB only):
one pc: 8 euros each plus S&H and paypal fees.
from 2 to 4 pcs= 6 euros plus S&H and paypal fees.
from 5 to 6 pcs= 5.5 euros plus S&H and paypal fees.
from 7 to 10 pcs= 5 euros plus S&H and paypal fees.
chassis available at
www.designbuildlisten.com APP STUDIO ING. PSU2 , CONFIGURABLE PSU BOARD KIT --> available on the new 2014 version This is an high performances PSU board designed for mic preamps.
I have designed this PSU board for the many requests of API 312 clone channels around here.
For this PSU project I started from the typical DIY preamp configuration of 2 or 4 pre channels inside 1u rack chassis. Moreover, if needed, the PSU can be easy set for dual 24V out for 4x M1 channels.
Since the space is very important when there are both 4 channels in the same 1u rack, I gone for a compact size PCB with narrow and long form.
This project was developed around the famous LM317 and LM337 IC regulators, with a design oriented for low noise and fast response to the load's current.
PSU's out voltages are set by 3 multiturn trimmers, one for each out.
the out voltages range is from +/-14V to -/+28V on main outs The APP PSU2 has dimensions of 5.28 inch X 2.05 inch (13.4 cm X 5.2 cm ) and is made with a professional FR4 two layers PCB.
current specs:main outs= +/-800mA (with proper heatsink)
+48 out = 50 mA
PRICES:
one APP studio PSU2 kit:
prices (S&H prices exluded).
22 euros 1 pc,
20 euros from 2 to 3 pcs,
18 euros from 4 to 10 pcs
APP studio PSU2 PCB only:
from 2 to 4 pcs= 7 euros plus S&H and paypal fees.
from 5 to 6 pcs= 6 euros plus S&H and paypal fees.
from 11 to 20 pcs= 4 euros plus S&H and paypal fees. Note: Power Transformer not included.
APP1040 mic/di preamp board.
This is a new design mic/DI preamp board with high performances, to be precise it is not a 312/512 clone or M1 clone but another best.
It can use several trasformers on input and on out and also all my DOA's, and moreover a lot of other DOA's in the market as the 2520 and the JE-990 too. APP STUDIO ING. METER 2 , CONFIGURABLE 10 LED METER --> available METER 2 is an high performances meter using 10 LED's (it can be used with 8 led's too) and the LM3915 led driver.
It has power supply voltages that go from +-16V to -+24V, regulated or unregulated.
The 0 dbu LED can be set using a trimmer. Each step is of 3 dB.
Changing some resistors' values it is possible to re-define the LED scale.The meter in the following pic is set with the scale that goes from -12 dbu to +15 dbu.
Being a new product are availables only the PCB's at the price of 9 euros each plus S&H.
for contacts PM me
Disclaimer (it must be read before ordering and/or paying):
- These products must not be used inside equipment for sale. Commercial use is denied without written and signed authorization of the product's designer (Pier Paolo Abbate).
- jurisdiction for any legal dispute is Italian, in any case the competent court is the court of Palermo in Italy.
- there is no warranty on these products, the seller does not assume any liability and/or any penalty for them in any case.
- these products can be very dangerous so they are only for persons who are very expert in electronics, if you're not very expert in electronics, than do not buy these products.
- these products must NOT be used for life supporting and/or for military applications in any case.
- these products are NOT suitable for life supporting and/or for military applications.
