Identifying LED switches
Geert Samuel
Member
Hi all!
I have a Tonelux vrack setup. On there are round white knobs with a led in there. I’m actually looking for a kind of replica designed momentary switch. The same type/idea is used the API 512v version. Is there maybe someone that can lead me the way? I’m building my custom daw controller and would be great to have those matching.
    271.8 KB
    1.1 MB
    2.6 MB
    267.5 KB
Generic PCB-mount pushbutton (no integrated LED simply for reason of cost and maintenance). Plus LED of choice added close to / under the switch 'at front edge of PCB' (closest to hole in faceplate). Several manufacturers do it that way.
Then cover with transparent but frosted white "switch cap" acting as light guide.
Some transparent plastic (maybe acrylic, but I might be wrong) turns milky white when exposed to heat.
Also I had some transparent plastic frost up when acetone was applied. Wouldn't want to 'sandpaper' tiny switch caps ;)
Hi all!
Those look somewhat like the E-Switch WBL series switches.
https://www.e-switch.com/parametric-search/?4=WBL
Some random stock of those at Mouser and Digikey.
Bri
