Peerless 15067 gets cut deep and wide..
CJ
GDIY Supporter
California
lonely?  think of the transformer that has to die alone, now what are you thinkin? see what it's like?
what is this thing? i guess you plug in a 70 volt speaker line, and you tap off of this auto transformer,
low voltage secondary means lots of current, but you can just lay the wire right on top of each other.
it would have taken 3 days to do a de lam, so we went midevil to get the 400 turns counted>
we  can use the root 2 thang,
400 turns, but each of the three windings has an inner and outer, so the core see's 200 T,
the current just is split in two. so we can use 200 turns as the full winding total.
so if we want 1/2 Z,  divide 200 by 1.41 and you get 141 turns for the 1/2 winding.
then we divide that in half to get the 1/4 Z wind, 141 / 1.41 = 100 turns, so we have
Common - 100 T -  141 T -  200 T
