Hi Audiox,
I am NOT really qualified to make this comment other than as an end user of vast amounts of outboard, and I would hate to disagree with you guys who A B'ed with 5534 and m100. After all, I wasn't there. But in my experience, you often can't hear much difference, 'til you have a long processing chain on, say a vocal, where the sibilance tends to rear it's ugly head at the end of the chain. Then, it can make a lot of difference as to what op-amp you use. I don't mean Discrete op-amp good, ic bad either . . . .
I also like the idea of using DOA so that you can halve the input level, and operate away from the extremes of voltage swing, making up +6dB with a tranny. Also seems to make things sound a bit "faster"(wholly un-qualified statement btw!). (Could this be that the op-amp limited slewrate effectively has less effect, 'cos you are not asking it to make so much voltage gain in the same timeframe?)
I certainly don't mean to criticise. I will be building itwith 5534 or anything else! There are I'm sure others who subscribe to the idea of a discrete in there, and personally I am itching to try out your OA10!
Many many thanks, and Kindest regards,
ANdyP
. . . . there is also the Kudos of knowing that there is a discrete sitting in there . . . .
