Highly appreciated - thank you!Here you go.
Perhaps they were chosen to give more sturdiness to the PCB/panel connection?
Potentiometers are 16mm Omegs (to keep the costs down):
P1 = 2x 22K LIN center detent (order code OM-01-023)
P2, P3 = 2x 10K LIN center detent (order code OM-01-005)
P4 = 2x 100K REV LOG (order code OM-01-059)
Thanks for the pointer. Found them at post #573!I have all the docs saved but I think they've been posted in the thread before. Maybe they could be attached to the first post?
Hi Ricardus. How you doing?Yeah, reach out to Frank.
I did silver with blue.
I'll need to look some stuff up, so hit me back here so I see an alert to remind me.Hi Ricardus. How you doing?
I'm about to design my front panel, I just wondered what is the size of your switch cap? (two pairs on the right), they look smaller than the pair on the left.
The pair on the left is the original design, isn't it? I'm struggling a bit to find that switch cap (the 10mm original Audiox's front panel design).
Ip
I'm out on a limb here, as I've not worked on a 169, so I'm answering from theory rather than experience. However, assuming both ends of the pot are tied into the circuit, the mid-point will be determined by the ratio of the resistance between pin2 & pin3 to the resistance between pin2 & pin1 - hence I'd expect the mid-point to still be zero gain regardless of whether you use a 20k or 22k pot.Can I use a 20k linear pot for P1 (Low Gain) instead of a 22k?
Would it be correct to say the mid point (zero gain point) will be shifted? I assume 11k of resistance will be the center point, and on a 20k pot the center point would be 10k.
Then also I assume I'll be losing a bit of dB gain at the upper end? which would be fine as I don't ever push them anywhere near that far.
I'm asking because I'd like to mod my unit to have detented gain pots and cannot find anything for P1 (But I can find a 20k)
Appreciate any help
The low gain pot is already given some separation by the resistors R6 and R7. So, in the event you find that using a 20k pot for P1 causes some unexpected and unwanted interaction between the HI and LO paths (which I think is unlikely), the best first step IMO would be to adjust (slightly increase) the values of R6 and R7.Thank you @DarkSky appreciate the explanation.
In the end I went ahead and ordered. it's an Alps pot rated at 20% tolerance, so hopefully will do the job. Not sure if you're going off general theory or seeing the schematic but the Low Gain pot seems to work in conjunction with the High Gain, hopefully the small resistance change won't affect that. If so like you say I'll try the 1k resistor mod.
Cheers @DarkSky, as you suspected all went well, no mods required.
Everything's tracking very well and the detented gain pots are a massive improvement as I tend to use these in stereo most of the time.
Guess it's time to add some pics to the thread then. The panels still only have the drill guide on there, will finish them off later.
View attachment 125841View attachment 125842Does your wiring work for the freqs? Audiox explained it differentlyearlier. I'm having trouble understanding how to wire the freqs even though it's already in this forum.
That's what confused me since Audiox said it didn't work but it's because of the change of the capacitor at C4 in the diagram right? You kept C4, C5 and C6 as stock version right? Sorry noob questions..@mooksnook do you mean for the frequency toggle switches? Yes they all work great. I used this wiring: View attachment 128726
