Thanks for explaining Cyril
Thank you! my other project was a success, more info here:API 1608 expander micro | RealgearonlineWelcome back Paolo! Everyone burns out on projects sometimes, don't worry at all about that - just glad to hear you're ok. Hope your other project was a success.![]()
Early Helios channels used the 2180 pre-amp,, followed by the switched passive bass filter which requires a high impedance follower, the EQ section requires a low impedance drive., the voltage follower provides both. Later modules incorporated the VF on large circuit boards using a 16 way connector. I have reduced to this design and thus lessen the cramped nature of components behind the front panel.
Here is a plea, for those constructing the early modules please use a small relay adjacent to the input transformer to change the microphone phase or move the phase switch to the top of the module. The module could be more stable at high gains if the microphone input cables and switching remain at the top of the channel away from high level signal levels..
Cyril
