templemark
- Joined
- Mar 31, 2009
- Messages
- 57
Hello all!
I recently picked up a soundcraft 500 series 24 channel board to do mixing OTB. I have a bunch of spring reverbs, tape echoes, compressors etc I like using in my mixes but frustrated by the latency involved with Digital Mixing. This new board has 6 Aux sends so pleanty of routing options.
However I heard a rumor that one downfall of this board is the line inputs are actully not 'traditional' line inputs but rather -30 db padded inputs sent into the mic-pre. Im not sure why they choose to do this, (save $ on 24 additonal 10k Pots?), but I checked the schematics from Soundcraft website and it looks correct. I'd rather not mix through the mic preamps if possible.
I plan to use this board only as a line mixer, (I have other additional preamps), so I am looking to modify all channels for line level and I dont care about disableing the micpreamps. I'd like to accomplish this with as little jumpers and additional components as possible. The faders must be configured to control the line level gain, rather than micpre gain.
Schematic for the input module is shown below:
My initial thoughts were to bypass the transistors and bring the line level input signal directly to IC1A, which happens to be a TL072 Opamp. Then I would use the Fader in the negative feedback of the opamp to control the gain. I put the circuit into SPICE to simulate this.
The overall output gain is a little different when compared to the original configuration, (it clips at about 85% fader level) but it actually looked good otherwise in the simulation and the frequency response was improved!
I am somewhat new to this board and circuit mods, so feedback would be appreciated! Im sure im overlooking many things.
