MatthewF
Hi everyone,
I've searched around on this topic both here and on the web in general, but haven't found any specific answers yet. Maybe its a stupid question! Here it is anyway:
Is it acceptable to exceed a valve's specified maximum plate to cathode voltage for a short time (i.e. at startup, before the cathode is hot and current is flowing)?
I'm currently playing around with a few valve circuits and have a PSU which, unloaded, sits at 400vDC. The valve I'm interested in is the 5842 which has max plate to cathode voltage of 200v. I can, of course, set the resistance in the power supply's CRC filter such that the plate voltage will always sit under 200v when the valve is operating normally. My concern is about the risk of internal arcing for those few seconds where no current flows and the plate sees 400v. I guess the obvious answer is to use a more appropriate power supply, but I get the feeling this scenario will come up quite often while throwing test circuits together with a generic PSU...
Thanks for any comments on this!
Matthew
Matthew
