pucho812
installed a soundcraft ghost over the weekend. Wired it all in, etc etc. I have noticed 2 things from the brand new board. One is common on all ghosts I have had to tech. The common thing is that the group output pcb's have cold solder joints and or loose ribbon connections causing the group to either not work or have low output volume. If I tap the boards the outputs sometimes come good and others good bad and it's a back and forth. If I really slam the group with level it can come good again. This has been on a new ghost fresh out the box as well as a ghost that was purchased new over a year ago. The second thing I have noticed on the brand new one is that it had a burning smell when first powered up. Wonder what was burning in as nothing was faulty other then the previous mentioned problem. so I wonder if this has been just a bad production run or what?
