The is the official support thread for the SB4000 project. Documents related to the build (assembly, calibration, templates, etc.) will begin to trickle in over the next week or so.
I ask to please keep this thread clean and friendly.
All further questions, issues, comments, etc - please refer to this thread.
BOM:https://www.dropbox.com/preview/SB4000_REV4_BOM_2020.pdf?role=personalQuad VCA BOM:https://www.dropbox.com/preview/QVCA_REV2_BOM_2020.pdf?role=personalBuild Manual (UPDATED 2/28/2011): (Approx. 13 Megs)
https://www.dropbox.com/preview/SB4000_ASSY_DOC_REV3.pdf?role=personalFrontpanelexpress File for Parmetal (Machining Only, No Text)
https://www.dropbox.com/preview/SB4000_REV5_PARMETAL.fpd?role=personalNote: for Modushop you can modify the mounting hole locations
_______________________________________________________________________________________
Update*
Send/Return - There seems to be alot of confusion on how this gets wired. Well, there is no set way, it should be wired whichever way works for your rig. It is an
UNBALANCED signal.
Typical way is to tie both "sends" on the board together and tie both "returns" together as well. Then, connect the "sends" to a 1/4" TS connector and same with the "returns" This will allow you to now send a mono unbalanced signal out of the compressor to your board, and also send a mono unbalanced signal to the compressor for ducking.
Alternatively, you could wire the "sends" and "returns" to an XLR connector (ie: the "sends" to XLR Pin 2 and the "Returns" to XLR Pin 3), but then you'll need a "Y" cable to break them back out to 1/4" TS.
QUAD VCA Boards:Please note typo in the silkscreen on the VCA boards (BOM is correct) - should be a 0.1uF Film Cap, not 4.7nF. If using the QUAD VCA boards, you must install JMP8 & JMP9 on the backside of the main board. All of the components within the VCA boxes on the SB4000 main board are not to be populated. VR1/VR2 would be best changed to 10K, however you can leave it at 50K if you'd like. Turn the pot fully counterclockwise to start, and then slowly turn clockwise to calibrate for unity Gain (the target resistance is 5K, so for a 50K pot you won't have to turn it much)
For remaining changes to SB4000 Main Board, see the Quad VCA BOM above.
Calibrating for lowest THD with Quad VCA boards:Easiest way to calibrate THD is feed a 1K test tone into compressor and look at the return signal with a freq analyzer in your DAW. (I recommend to download Blue Cat's Freq analyzer for this.) Distortion node will be seen at 2K, adjust until 2K node is as low as possible.
Engage the "External In" so the sidechain is disabled (Of course be sure there is no external signal being fed to the external input).
Adjust DTRIM Pots (VR3/VR4 on Main Board) for lowest THD. Then turn front panel gain knob to Max (lower the input signal as required so signal doesn't clip). Now adjust the 50K Pots on the VCA boards for lowest THD. Return front panel gain knob to 0. You will need to repeat this process a few times until lowest THD is achieved.
