SB4000 Support Thread
Thanks unfortunate mate as those SB4000 boards were really good.
I guess Serpent Audio decide to quit the DIY bussiness and just start selling already built products.
Is that even any SSL bus comp pcbs being sold at the moment?
The GSSL PCB was really outdated as it needed a lot of addons, but even that one I don’t see for sale
PCBgrinder still has GSSL.
Have to say a lot of parts for the SB4000 are getting hard to source.
Same as with MNATS FET500.
I see, but it's a pretty outdated board the GSSL, it's around 18 years old, it was never updated. You need a separate Turbo Board, separate PSU extra filtering and a SideChain board. It's just messy to do it.
Later SSL bus comp projetcs like the SB4000 and Igor's Mixbuss had all the circuits built in the same board, it made completely sense
Hello all, long time….
I’ve recently got my sb4000 back and had a rewire/solder of the Xlr connections and new THD resistor pots. For some reason the now when in bypass the unit is 6db quitter than the input signal. I’ve searched the thread but can’t really find an answer other than something to do with Xlr shorting to ground but I’m sure the Xlr connections are fine.
The unit sounds amazing but I can only use it engaged and have had to trim the unity gain pots up by 6db for a like for like in/out signal.
Am I missing something really simple here???
Attached a picture of the unit cos it looks noice 😂
    1.1 MB
Since the bypass just routes the in to the out (if I remember correctly), I’d put it in bypass and check continuity between each pin of the corresponding I/O XLR’s first (In Pin 1 to Out Pin 1, then 2 to 2, etc.). Also check for continuity between pins on each connector itself, especially 3 and 1, to make sure they’re not swapped and 3 is accidentally going to ground. Sounds like you’re missing a leg.
So I just broke the HPF rotary switch when trying to change the knobs….gutted. Fully split open and the two little ball bearings came out, it’s like it exploded.
After looking at the original BOM I can’t seem to find the exact switch to buy to replace it.
Will this one be ok?
https://uk.farnell.com/lorlin/ck105...NJNgJZ1FotD5XzhBw3o6udZ2YURMQyiRoCaaEQAvD_BwE
Kinda baffled at all the various options…
Again apologies, I’m still new hahahah
Longshot. Troubleshooting an SB4000 I never completed.
Having trouble getting any movement on the gain reduction meter. It's pinned left.
Audio path is okay. Makeup gain working, but no compression.
Voltages are correct.
Noticed U13 (the TL072) gets very hot. Even upon replacement. Makeup gain is functioning, however.
Some weird observations in the Right SC circuit. I see signal at TP12 and can calibrate VR7, but at voltage divider R79/R78, the signal disappears on VCA in (U9) when THAT2181 is present. Swapping L/R VCAs does not resolve, and problem is not present on Left SC.
In mono mode, I see a rectified signal in the Left SC circuit, but no idea what correct function should be.
I wonder if SB4000 rev5 boards' ferbers are available somewhere. In general I do not understand if someone stops selling it / building it forever, why not pass it for future generation. I mean if you won't make any profit anymore, why you could not serve community. Just a question, I'm really curious about the answer, no offense.
I agree that it would be nice if it were still made available in some form, but unfortunately I think that's just not the case. Serpent has moved entirely into commercial offerings, including their 500-series version of the SB4k. You may still be able to find some unused pcbs for sale if you post a wanted ad in the Black Market. I might also suggest checking out @Gustav 's recent offering to the forum, the GSSL 20th Anniversary project, which fills a similar niche with some neat functionality options.
Yes, exactly that is on my list. And it was an unexpected, unprecedented warm Xmas surprise from him. Very nice!
Here you go. This is the BOM, build guide, schematic, and the BOM for the Quad VCA if you are going that route.
I have annotated parts of this for my own needs (I changed a few things in my most recent build), so please feel free to ignore those annotations if they are visible when you open the file.
Thank you! Ready to do some work on my old SB4000 build and was freaking out because I couldnt download the manuals. Time to archive all of the BOMs for all of my projects before the internet forgets what hardware is all together.
