bruno2000
Greetings folks,
Here is my offering of SSLTech's 9K Pre Amp in the 500 / 51X format with some extras. The extras are the SSL style HPF, a THAT 1646 output stage, and a 3 dB per step meter.
You'll need a fine tipped soldering iron, and a fairly steady hand for this project.
Here is Gustav's beautiful board with the resistors and bypass caps installed.
The meter LED's need to be bent about 1/4" from their bodies. I used a pair of pliers as a jig.
I used Teflon tubing on the switch indicator LED's
Here's what it looks like before they are bent over the switches, and inserted into the front panel.
I cut some pieces of Teflon tubing to act as spacers for the meter board.
and slid them over pieces of bus wire soldered to the 4 corner eyelets of the meter board.
Here's how the meter is mounted.
There is a little problem with the first run of boards in that there is an unwanted connection between the power eyelet and the top ground plane of the meter board. You can see the extra silver that the "arrow" is pointing to. Just take a blade, and carefully cut this extra copper away. You can check your work with an Ohmmeter to the eyelet on the lower corner. It should not be a short.
Here's the BOM with some Mouser part numbers
http://www.dopplerstudios.com/pictures/SSL 9K-42BOM.pdf
Here's the layout with the 100nF Bypass caps marked in yellow.
http://www.dopplerstudios.com/pictures/SSL 9K-42Layout.pdf
Here's the schematic.
http://www.dopplerstudios.com/pictures/SSL 9K-42Sch.pdf
Here's the wav file of a sweep from 1kHz down to 10Hz from our Audio Precision System One to use in the HPF knee alignment. (Right click and "save as".)
http://www.dopplerstudios.com/pictures/1kHz-10Hz_Sweep.wav
Here's a Front Panel Express layout you can customize to your specs.
http://www.dopplerstudios.com/pictures/SSL9K42.fpd
Here is the very nice front panel designed by ChrisPSound
http://www.dopplerstudios.com/pictures/SSL9KChrisPSound.fpd
Gustav has the boards in his White Market thread.
Audio Maintenance will have both of the needed pots.
Apex Jr. has the relays.
More photos to come, as well as the SSL 4K series transformer mic pre in this same configuration.
Enjoy!
Bruno2000
edit 3/17/2011 for Chris' front panel
Enjoy!
Bruno2000
