Re: LA3A 500 BUILD
« Reply #500 on: March 21, 2015, 05:08:31 PM »
Will these pots work?
100K-Ohm Audio-Taper Potentiometer : Potentiometers | RadioShack.comhttp://www.radioshack.com/100k-ohm-audio-taper-potentiometer/2711722.html
Link doesn't work for me, but 100k audio taper appears correct. Check dimensions for fit.
Ok next question. Do the EL Panels have to light up green???? I found blue but I want to be sure before I pull the trigger
Re: LA3A 500 BUILD
« Reply #501 on: April 20, 2015, 10:17:53 PM »
I got my El panel finally working. ended up having a short. That is now rectified, but I am struggling with an other issue.
The Squish (comp) pot will adjust the output of the panel, but so will the Output pot. I can have the "squish" all the way up, but if I back off the output the El Panel will dim. I am also not seeing compression of the signal, but I do see a change when engaging the Comp/Limit switch.
Any thoughts?
dmp
Re: LA3A 500 BUILD
« Reply #502 on: April 22, 2015, 05:41:57 PM »
I don't think the gain pot should not affect the EL panel at all.
If you aren't seeing compression, be sure the EL panel / cells are enclosed from room light! This thing doesn't work if you can see the EL panel lighting up.
The cells should react to blue as well, I don't know how the EL panel you have will behave though.
Here's a source from a groupdiy'r if you don't know of it:
https://sites.google.com/site/diypartsstore/catalog/new-t4b-opto-el-panels
Re: LA3A 500 BUILD
« Reply #503 on: April 22, 2015, 09:55:16 PM »
@dmp
That's a double negative, hopefully you mean that the gain pot should not affect the EL panel?  Thanks for replying. .. I will look into it more.
dmp
Re: LA3A 500 BUILD
« Reply #504 on: April 23, 2015, 09:31:34 AM »
Oops- that is not how I meant to write that.
The gain pot is after the gain reduction, so it should not affect the EL panel.
Re: LA3A 500 BUILD
« Reply #505 on: September 16, 2015, 12:55:41 AM »
hey all did any one else have issues will the comp/limit switch not making any difference and also did you find that the input gain seemed low so you didn't get much compression like only 5db  on max squash??
thanks
dave
Hummingwire
Re: LA3A 500 BUILD
« Reply #506 on: May 13, 2019, 10:48:51 AM »
Any chance this project will get some new life blown into it again?
I'd love to build one of these  ;D
Rob Flinn
Re: LA3A 500 BUILD
« Reply #507 on: May 13, 2019, 12:15:55 PM »
Not likely from LAZpro.  Peter disappeared off the radar a few years ago.    The last contact I had with hm was a few beers in London about 6 years ago.
regards Rob
Hummingwire
Re: LA3A 500 BUILD
« Reply #508 on: May 13, 2019, 04:00:06 PM »
Too bad, I hope he's ok  :)
Can you (or anyone) recommend another DIY opto comp on here? I tried searching but this was the only one I found.
Fuzz Face
Re: LA3A 500 BUILD
« Reply #509 on: May 14, 2019, 09:55:29 AM »
DIYRE has an optical compressor kit
https://www.diyrecordingequipment.com/products/ola5-opto-compressor-kit
Serpent Audio has some LA3A boards
https://serpentaudio.com/product/sa-3a-pcb-blank/
TwentyTrees
Re: LA3A 500 BUILD
« Reply #510 on: February 28, 2020, 03:48:51 AM »
It's a long shot as it's been a while, but does anyone have any of the docs available for the LAZ LA3A? I recently picked one up second-hand, and though it sounds great there are a few issues which a schematic and / or layout would make it much simpler to troubleshoot. All the links I've found in this thread and elsewhere are long dead.
dmp
Re: LA3A 500 BUILD
« Reply #511 on: February 28, 2020, 09:35:33 AM »
DLA2A!
I've built both and the LA2A is the best. It's tube however and bigger.
dmp
Re: LA3A 500 BUILD
« Reply #512 on: February 28, 2020, 09:38:58 AM »
Yes, I have some docs
dmp
Re: LA3A 500 BUILD
« Reply #513 on: February 28, 2020, 09:41:18 AM »
layout
dmp
Re: LA3A 500 BUILD
« Reply #514 on: February 28, 2020, 09:44:10 AM »
board 1
dmp
Re: LA3A 500 BUILD
« Reply #515 on: February 28, 2020, 09:47:14 AM »
board 2
dmp
Re: LA3A 500 BUILD
« Reply #516 on: February 28, 2020, 09:48:20 AM »
board 3
dmp
Re: LA3A 500 BUILD
« Reply #517 on: February 28, 2020, 09:52:19 AM »
BOM
Rename to .xls
TwentyTrees
Re: LA3A 500 BUILD
« Reply #518 on: February 28, 2020, 03:43:22 PM »
dmp, that is absolutely spectacular - THANK YOU for your help! Raising a glass to you from a grey, rainy London.
Last post June 05, 2004, 01:24:12 AM
by rafafredd
Last post December 24, 2008, 03:47:00 PM
by gary o
Last post January 13, 2009, 03:18:43 AM
by Jim Zuehsow
Last post September 16, 2018, 12:50:37 PM
by kosi
