I have had problems mixing bass. On my monitors it sounded fine but on lesser speakers it was too low.
I did some research on Auratones and decided to have a go at making some, the results were much better than expected and they have solved the problem at minimum cost.
I first needed to find the frequency response of the Auratones to find a matching loudspeaker. After some time, I found it on page 63 of the SAE magazine 01 2009. EDIT. Now attached
Next I found a cheap Chinese speaker from Maplin in the UK which had a good matching response.
www.maplin.co.uk/Media/PDFs/L69AW.pdfThis speaker is shielded like the Auratone and is the same size.
They cost about £16 a pair which is about $25.
I calculated the internal volume of the Auratones to be 2.23Litres and they a have a 1 inch lining of BAF on the walls. I used the wadding from an old duvet! Auratone dimensions are 6.5x6.5x5.5inches deep. I made them half an inch wider at the front but kept the internal volume the same, using 0.5 inch chipboard/particle board, with 20mm corner bracing.
Just for fun I made them look old with some varnish and stuck a label on them!
http://i1110.photobucket.com/albums/h448/DBPendrill/Front.jpghttp://i1110.photobucket.com/albums/h448/DBPendrill/Back.jpgThese speakers have helped me solve the bass problem and sound much better than expected. No real bass below 100Hz or top end above 10K but really useful nevertheless.
This forum is all about DIY and there are better cheaper ways than being an Ebay slave.
