Auratone DIY
France
I have had problems mixing bass.  On my monitors it sounded fine but on lesser speakers it was too low.
I did some research on Auratones and decided to have a go at making some, the results were much better than expected and they have solved the problem at minimum cost.
I first needed to find the frequency response of the Auratones to find a matching loudspeaker.  After some time, I found it on page 63 of the SAE magazine 01 2009. EDIT. Now attached
Next I found a cheap Chinese speaker from Maplin in the UK which had a good matching response.
www.maplin.co.uk/Media/PDFs/L69AW.pdf
This speaker is shielded like the Auratone and is the same size.
They cost about £16 a pair which is about $25.
I calculated the internal volume of the Auratones to be 2.23Litres and they a have a 1 inch lining of BAF on the walls. I used the wadding from an old duvet!  Auratone dimensions are 6.5x6.5x5.5inches deep.  I made them half an inch wider at the front but kept the internal volume the same, using 0.5 inch chipboard/particle board, with 20mm corner bracing.
Just for fun I made them look old with some varnish and stuck a label on them!
http://i1110.photobucket.com/albums/h448/DBPendrill/Front.jpg
http://i1110.photobucket.com/albums/h448/DBPendrill/Back.jpg
These speakers have helped me solve the bass problem and sound much better than expected.  No real bass below 100Hz or top end above 10K but really useful nevertheless.
This forum is all about DIY and there are better cheaper ways than being an Ebay slave.
  • SAE Magazin 1 2009[1].pdf
Different solution to a similar problem:
http://dibsreaction.com/the-old-studer-speaker-trick/
Nice work!
Thanks Guys,
As they say, "necessity is the mother of invention".
If you gradually up the frequency of a shelving bass boost so it sounds right on these, it also sounds right on the bigger monitors only deeper.
best
do you know any source for the loudspeaker you have used, outside of the UK? Maplin unfortunately does not offer shipping outside of the UK and they also have no distributors here in Germany.
+1 and maybe some pictures inside the cap... What amp is driving them?
Nice job....  ;D :D :D
Søren
Hi Guys,
I thought this post was finished, anyway:-
Majestic12,
I don't know where else you could get them other than doing an internet search using the part number, it does surprise me that Maplin don't ship overseas, very short-sighted of them.
Soeren_DK,
There is nothing to see inside the cabinets really, especially as the walls are covered in fibre.  The construction is simple, the panels are glued and pinned to 20mm section softwood without butting the corners (corners are filled using quadrant section).  There is no internal amp, they are driven from a 25W/channel sony hifi amp.
sodderboy,
The magnets have a metal shield over them, check the Maplin page. www.maplin.co.uk/Media/PDFs/L69AW.pdf
The original Auratones had these too, I understand, so that they can be put next to a TV or monitor without the magnetic field from the magnets distorting the screen image.
best
very interesting project...
I'm really tempted to try it but for some reason I'm 'afraid' of the woodwork.
Doesn't look very complicated but I have zero experience in wood construction...  :-\
Warpie,
This is all you need:-
handsaw, pin hammer, pin punch (old screw will do) pencil, setsquare, old knife for filler, wood rasp or file.
sandpaper coarse and medium. paintbrush.
woodprimer, paint, varnish containing stain.
best
No, I looked as well, nothing.
Monacor or Visaton are probably your best suggestion, you have the Thiele Small info for the speaker so go for the best match to that.  It has to be a type that can cope with being in small box of 2.3l volume.  You can download WinISD to check the performance.
best
OK, speakers arrived today... ;)
Hey Dave, thanks for sharing this simple and nice idea by the way!  :)
One question, the original cabinets were made with chipboard from what I read.
Is this the reason you used chipboard too? I'm just asking because I try to decide whether to use chipboard or MDF...
thanks
michael
Hi Warpie,
I used chipboard because of the original so it might have similar resonance, but the panels are so small it may not matter anyway.  I joined it all together with glue and panel pins, but I drilled the wood or board the pins pass through first (not the lower part the pins bite into), punch just below surface then fill.
good luck
