mikefatom
HZ51X Build & Help
Project's Original Thread
Documentation
1 - HZ51X BOM
2 - HZ51X SCHEMATIC
3 - HZ51X FPE DESIGN
Next post is reserved for assembly tips/help.
« Last Edit: September 20, 2015, 11:21:12 AM by mikefatom »
mikefatom
Re: Whistle Rock Audio - HZ51X Recording-DI - BUILD/HELP thread
« Reply #1 on: March 20, 2011, 08:29:52 PM »
About the Basic Kit
1- The basic kit contains a small hardware baggie with the following:
  • 4 x SEMS screws.  These are for mounting the PCB to the bracket.
  • A U shaped heatsink for the voltage regulator U1
  • Hardware to mount the heatsink to U1.  The insulator is optional but don't forget the thermal paste!
2- The PCB sockets for the Hi-Z Plugins must be press fitted in their holes.  Use the rubbery handle on a pair of pliers to push them all the way against the PCB if needed.
3- Use single core wire and some heatshrink tubing to mount the LEDs from the PCB to the panel.  22 gauge wire will do.
4- Watch the orientation on the relays! They are marked at the top.
5- Even though it's not critical, try to line up the Neutrik input jacks as best as possible.  They are meant to hang over the PCB a tinny bit by about 0.5mm.
6- Try to get the switches to be as parallel as possible to the PCB.  There are 2 plastic tabs at the bottom of each switch that are meant to sit on/touch the PCB.  You'll know that you have the switches installed right if both of them are touching the PCB.
7- Installing the switch caps will require some force but be gentle... ok?  Use a drop of soapy water if required.
8- Check your supply voltages for each IC at the IC sockets BEFORE inserting the ICs.  You should read 5V at pin 14 of U7, pin 14 of U8 and pin 16 of U6.  This may require a special test rig which I suggest you put together if you're planning on building more 500/51X series projects in the future.  Otherwise, if you like the thrill of potentially f'ing things up, install all ICs and slide your shiny new HZ51X in a 500/51X rack, do the smoke test and hope for the best...  :P
9- For 500 series use only: Cut off the extra 51X tab.  You may omit C12, C13 and D13.
About the Hi-Z Plugin Kits
1- Regarding the passive Jensen/Cinemag Plugin:  Try to mount the TX as close as possible to the plugin PCB.  Every 1/2mm of height counts.
2- The 6.8K resistor is not required if using the Cinemag TX.  Install it only if you're using the Jensen TX.
3- Check your voltages at the sockets before inserting the active Plugins.  Same deal as point number 8 in the previous section above.
That's all I can think of right now but I will come back to this post and add some photos and more tips if I think of any more or someone else brings them up.
« Last Edit: March 23, 2011, 07:44:24 PM by mikefatom »
mikefatom
« Reply #2 on: March 23, 2011, 07:48:19 PM »
Tips and fancy glamour shot added.  ;D
Snatchman
« Reply #3 on: March 23, 2011, 08:19:52 PM »
Nice..How does it sound..?
Thanks for your time and ears!
mikefatom
« Reply #4 on: March 23, 2011, 08:27:17 PM »
It sounds like whatever Hi-Z plugin you are using through whatever preamp you choose to use it with.
Check the original thread for my thoughts on the different Hi-Z plugins.
Mike
« Reply #5 on: March 27, 2011, 01:30:11 AM »
well done mike, took me a *very* leisurely 2 hours (i stopped to make and drink a chocolate malt, if that's any indication of pace ;D).  those sockets are top notch, wish i would have known about them 24 preamps sooner!
for when everybody else starts in, the sockets aren't terribly tough to get seated but i'd suggest putting them in before you mount the jacks.  not very difficult to do after the jacks either, just would take less maneuvering to do it beforehand.
« Last Edit: March 27, 2011, 01:36:05 AM by grantlack »
There's nothing like the right tool for the job.
And -usually- that's what I end up using...
..nothing like the right tool for the job!
mikefatom
« Reply #6 on: March 27, 2011, 01:36:44 AM »
Thanks Grant!  :)
I really like those sockets as well. I will be using them in all my projects from now on.
Mike
« Last Edit: April 09, 2011, 07:09:29 PM by mikefatom »
JamesW
« Reply #7 on: March 27, 2011, 11:38:26 AM »
Mike  it all went together well took me longer then 2 hours. Lots of gain from the active plugins. Very high quality kit!
Subject to change with out notice
mikefatom
nuts
« Reply #9 on: November 24, 2011, 06:09:34 PM »
Hi, i just pulled the trigger on a 51x rack and psu.
Does the Jensen Hiz plugin available now, somewhere ?
mikefatom
« Reply #10 on: November 24, 2011, 06:21:58 PM »
Hey nuts,
You will find the Hi-Z plugin PCBs/Kits from Classic API.  The Jensen transformer must be purchased separately.  I do have a couple of Cinemag DI transformers available if you're interested.  These are very nice substitutes to the Jensens.
Mike
nuts
« Reply #11 on: November 24, 2011, 06:42:21 PM »
Thanks Mike,  i thought there was a full kit like the others hiZ plugins.
So i have a chance to grab them with my VP26  kits i think.
Depending of where you live i'm not sure it will be cost effective to ship a single Cinemag to France.
But i'm interested yes, i understand they are a little less expensive than Jensen's. I will ask to Volker too.
I was sold on the Mooktronics DI before i seen yours...nice idea you had. I want both now :)
« Last Edit: November 24, 2011, 06:45:48 PM by nuts »
mikefatom
« Reply #12 on: November 24, 2011, 07:09:58 PM »
If you are ordering anything from me, I can send the Cinemag along of course.
I'm in Canada.  :)
Mike
Last post July 05, 2010, 09:12:37 AM
by mikefatom
Last post May 22, 2011, 09:16:50 AM
by [silent:arts]
Last post January 08, 2011, 02:14:49 AM
by mikefatom
Last post June 12, 2014, 06:07:27 AM
by prh
