True bypass relays + 12v PSU for Dual mono and Stereo project
This project is perfect for a GSSL, W492 EQ, and others…
Possess its own PSU and doesn't use the main power supply.
The PCB:
Here to buy the PCBs:
http://www.groupdiy.com/index.php?topic=44050.0
The links:
For stereo operation:
Link Left bypass and Right bypass, connect one switch on Dual bypass.
For dual mono operation:
Link Dual bypass and connect one switch on Left bypass and one switch on Right bypass.
Connect XLR inputs/outputs and inputs/outputs from the machine board.
It’s also possible to use the 12V to powered a Leds.
BOM:
1x diode bridge W04G
1x 1000uF 63v cap radial 7.5mm :
http://fr.farnell.com/jsp/search/productdetail.jsp?SKU=9693076
http://search.digikey.com/scripts/DkSearch/dksus.dll?vendor=0&keywords=ECA1JHG102
2x 100nF 63v poly 5mm, C1, C2
4x 1N4004 diodes
1x 7812 Reg TO 220
1x heatsink:
http://cgi.ebay.fr/TO-220-Heatsink-Small-Power-Aluminum-Heat-Sink-x-4pcs-/260481603013?pt=Vintage_Electronics_R2&hash=item3ca5e9d5c5&_trksid=p4634.c0.m14.l1262
4x relais RT424012F:
http://fr.farnell.com/jsp/search/productdetail.jsp?SKU=1608374
http://search.digikey.com/scripts/DkSearch/dksus.dll?vendor=0&keywords=RT424012F
11 or 12x 2 pins Molex (facultative).
1X switch for stereo mode or 2X switches for dual mono mode, of your choice.
