marktokach
I am using mogami mic cable which has 6 wires and a shield for my G7 mic rev. 2 pcb.
I believe I'm supposed to wire pin 1 of tube mic cable, which is now not wired to the braided shield of tube mic cable. Is this correct?
I believe I should connect pin 1 and pin 7 inside mic body before tube somewhere( or is it taken care of in the pcb already) and connect to body of mic and screen.
Is the ground to the body taken care of in the 7pin xlr in the mic body or do I need to run a wire to the mic body from somewhere else?
And then there's the hooking ground wire to screen. Not sure where to wire it from.
This is how I have it hooked up so far. Am I missing any grounds to chassis or is that taken care of in the xlr connectors?
7 pin xlr PSU connections
pin 1 Ground from IEC , pcb pin 1, and 3 pin xlr
pin 2 +160 v
pin 3 audio+
pin 4 audio-
pin 5 pattern
pin 6 +6.3
pin 7 0v
Mic cable connector connections
pin 1 not used
pin 2 +160
pin 3 audio +
pin 4 audio -
pin 5 pattern
pin 6 +6.3
pin 7 0V
Mic 7 pin connections
pin 1 ground
pin 2 +160
pin 3 audio+
pin4 audio -
pin 5 pattern
pin 6 +6.3v
pin 7 0v
pin 2 +160 v
pin 3 audio+
pin 4 audio-
pin 5 pattern
pin 6 +6.3
pin 7 0v
pin 1 not used
pin 2 +160
pin 3 audio +
pin 4 audio -
pin 5 pattern
pin 6 +6.3
pin 7 0V
pin 1 ground
pin 2 +160
pin 3 audio+
pin4 audio -
pin 5 pattern
pin 6 +6.3v
pin 7 0v
