Ricardus
Re: GSSL HELP THREAD!!!
« Reply #8340 on: November 26, 2020, 07:16:08 PM »
Its red? I thought I packed white in there now, but must have forgotten to change it many moons ago.
you can position it on top and use a hot glue gun to glue it in there, you can drill a hole in the meter to position it, or whatever you like.
Gustav
Yeah, it's red. I was wondering about that. I guess I'll replace it with white.
Audio mastering for hire..
Beeswax
« Reply #8341 on: November 28, 2020, 01:18:13 PM »
I'm getting more compression on the right side.  It isn't volume in the program material as I ran it through another compressor to test.  Thoughts on this?
« Reply #8342 on: November 28, 2020, 06:10:34 PM »
Are you getting more compression, or are the levels uneven, even with no compression?
If you are in fact getting more compression, did you install the turbo or something?
Gustav
gyraf
« Reply #8343 on: November 29, 2020, 09:33:13 AM »
..please, this is not a chat for online-solving problems without the need for digging into the underlying electronics.
You need to do some work for yourself, otherwise the whole idea of a help thread that other builders can use will be void. Read through this thread to find similar symptoms, try similar remedies to what is proposed as solutions.
Then, if none of those works, report back here with the symptoms ant the list of solutions that you already tried, and what results you had from that.
Then it will make sense trying to help you - otherwise we're just cluttering up this whole thread with one-time-solutions
/Jakob E.
ateshk
« Reply #8344 on: January 05, 2021, 01:34:44 PM »
My GSSL works just fine but I see there is a peak at 50hz at -90db. Its not audible but Its there in the spectrum analyser when there is no audio running through the unit. It looks like there are some harmonics also in the higher frequencies. why do u think this is happening? I have the ERC board too to filter the power after transformer. Thanks.
gyraf
« Reply #8345 on: January 05, 2021, 04:42:57 PM »
If its not audible, why bother?
ateshk
« Reply #8346 on: January 06, 2021, 04:39:44 AM »
So, is this a common issue?
I am using it but I want to fix it if it is possible.
gyraf
« Reply #8347 on: January 06, 2021, 08:10:16 AM »
Are you used to interpret measurement systems like your spectrum analyzer? That is, do you know exactly what it tells you, are you sure you're measuring correctly regarding terminations etc.?
/Jakob E.
Harpo
« Reply #8348 on: January 06, 2021, 10:56:34 AM »
Looks like induced hum at mains frequency. Rotating the mains transformer for least inducing hum might help. Distance is your friend. Greatest inducing field for usual is where the secondary wires come out of the assumed toroidal transformer. A halogen lamp shining above your gssl with lid open can cause this as well.
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.  -Douglas Adams
ateshk
« Reply #8349 on: January 06, 2021, 02:34:57 PM »
/Jakob E.
I dont check the units with that analyser on ableton live. I was working and checking the song with an analyser and when the song stops I noticed the hum. So, after that I eventually check the other units as I work with them. I have this hum/peak at 50hz only in GSSL and in 1 channel of an EQ unit that I have built. Its not audible for the EQ also. Maybe its the transformer as someone mentioned in a post below.
ateshk
« Reply #8350 on: January 06, 2021, 02:37:53 PM »
I have attached the picture. Can you tell if this is a tight layout? transformer too close to circuitry?
living sounds
« Reply #8351 on: January 09, 2021, 12:14:29 PM »
Make sure the + and - connections are wired correctly to pin 2 and 3.
Also, make sure pin 1 at each of the input and output XLR connectors directly connects to the chassis then and there. It should be enough to use a small wire to solder the pin to a screw that holds the connector in the cassis.
The mains safety earth should be bolted to the chassis close to the mains inlet.
The only connection between chassis and audio ground should be at the input of the ERC board, where it should go right down and be bolted to the chassis. Make sure that veroboard ERC board is wired correctly, same goes for the transformer primaries and secondaries.
Where does the green cable in your foto lead to? I would lose it and follow my above wiring guide. The shield connection goes through the chassis, which is connected only at these points: power inlet earth connector, ERC filter input, CLR pin, pin 1 of each XLR connector.
Check that the voltage after the filter board is sufficiently high to account for the regulator's voltage drop.
Check the power lines with a voltmeter and a scope, sometimes regulators are faulty.
If all of this doesn't help there might be a fault in the circuit somewhere on the board that is inducing hum. Is it the same for both channels?
From my experience with GSSL's (I've got 4) the ERC board and proper grounding procedure is enough to keep the hum below the noise floor. The transformer should not be a problem at the distance it is placed in the picture.
« Last Edit: January 09, 2021, 12:23:13 PM by living sounds »
ateshk
« Reply #8352 on: January 21, 2021, 04:06:47 PM »
Thanks for the detailed explanation.
I did everything here. All Pin 1 connected to chassis. Bolted with the earth from mains inlet. CRC board ground is now connected to Chassis at the bolt. I Check the voltages and find out that 7815 was not working properly so I replaced it. But, The hum is still there. Is there any schematic or a link to a schematic for the proper CRC board for GSSL? Is it also connected to main at some point? Inpult voltages on CRC board are 22V ac and output are +27.1V and -27.8V DC. Is this normal or am I missing something here?
living sounds
« Reply #8353 on: January 21, 2021, 08:29:18 PM »
Something is probably wrong at the input of the CRC board.
I can't see what kind of transformer you are using. For +/- 15VDC a center tapped dual 15V trafo will be fine. A dual 22V trafo would be excessive and force the regulators to produce a lot of heat. With the CRC board an 18V trafo might be best, since there needs to be sufficient voltage for the regulator to drop some.
You need a transformer with two identical secondary windings. If you don't have a drawing for the trafo, connect one wire from one secondary to one wire of the other secondary. Measure the voltage across the other two ends of the secondaries. If you measure a very low voltage and you connect those ends to each other, the windings will be in parallel, but if you measure about 30 volts, the wires you've already connected will be the center tap of a 15 - 0 - 15 secondary.
Take a look at the image. The blue connection between 4 and 5 is your ground and goes to the ground connection of the input side of the CRC board. The other two wires (3 and 6) go to the other two inputs of the CRC board.
Last post September 07, 2020, 08:47:47 AM
by Slime_Lord
Last post September 13, 2005, 06:21:43 PM
by clintrubber
Last post November 09, 2005, 07:52:12 AM
by Soeren_DK
Last post May 03, 2006, 10:57:52 AM
by jensenmann
