sr1200
So im working on a project, things are sounding awesome. I go to bounce to disk and i get HORRIBLE digital distortion. (none of my tracks are NEAR clipping and neither is the mix bus) so i remove some plugins... same thing... turn levels down... same thing... i remove all my hardware inserts and the problem goes away (UH-OH!)... I put one insert back in, and its fine... as soon as i put 2 or more its hell on earth. The analog units arent distorting and it sounds fine when mixing. So for grins n giggles, i tried recording the mix as another stereo track, and its fine. (then tried bouncing just that stereo track and no problems either) Any thoughts? i gotta get 6 tracks out by tonight and id prefer not to have to record to a new stereo pair if possible (well... that and its the principle of the whole things) it worked a few days ago no problems. the only thing thats changed is the monitor im using in the other room. I also noticed that my input monitoring when in low latency mode isn't working now either. But i can live without that for right now.
