soundguy
quad eight mic pre [pics]
« Reply #40 on: November 10, 2005, 12:29:40 AM »
its a pain in the ass to get them out but a really secure way to get them in and have them stay there.
remove the four bolts in the transformer.  Replace with a bolt about an inch or whatever longer.  Drill four holes in your chasis to line up with the holes in the transformer.  Slide new longer bolts through the chasis.  Put a plastic (you may need to use a metal standoff for the one position with the ground trace) standoff on the bolt, 1/4" will probably do.  Now mount the transformer and the pcb back onto the bolts and screw the nuts down on top of the transformer.  thats the way I mount all that type of stuff horizontally.  Its a bit of a production when you need to remove the amps to fix or swap components but its a great roadworthy solution, once you bolt it down, it aint going nowhere.
dave
chips are good with dip...
b3groover
« Reply #41 on: November 10, 2005, 12:55:41 AM »
So the one hole with the ground trace needs a metal stand-off so that it's grounded to the case?
soundguy
« Reply #42 on: November 10, 2005, 02:27:24 AM »
if I remember right it should make its way to ground somehow.  Its been a while since I looked at those.  I forgot my picture was sitting at the top of this page, thats how those are mounted in the chasis, like I described.
dave
b3groover
« Reply #43 on: August 06, 2007, 04:15:26 AM »
Holy sh*t!  After having this project on the back burner for at least 3 years (if not 4), I finally got all 8 of my Quad Eight cards racked up.  I just finished a few minutes ago.  Unforunately, I have one bad card, but I think it is the pair of diodes on the rails... should be an easy fix.
Check it out:
It's been so long since I started this project, I've misplaced four of the knobs!  Hopefully I can find them or I'll have to buy more.  D'oh!
The two holes under channels 1 & 2 are for Joe's direct input kits, however the 1/4" jack's threads are not long enough to go through the thick front panel.  I'm still figuring out a way around that.
Lots 'o iron in this bad boy.  It's whisper quiet, too, thanks to putting the power supply (one of Joe's kits, naturally) in a separate case.
My wiring is kind of a mess, but hey... it works!
Here's the power supply.  I'd like to say I came up with the idea of using an old computer PSU case, but I saw it on the web somewhere.  I have a million of these damn things lying around and not only do they have a lot of extra wires that can be used for short hook-up runs, but they make a great case for a small power supply.  You've already got a mounted IEC jack and a power switch!
I'm headin out of town for a week starting Tuesday so I won't have time to do any real tests, but I'm really anxious to try these on drums!  WOO!
« Reply #44 on: August 06, 2007, 03:02:41 PM »
Yeah!  I just started doing the final layout for my QE's too.  These were among the first DIY parts I picked up 4 or 5 years ago.  I just need to order up a couple of Joe's DI kits, drill the back panel and wire away.
b3groover
« Reply #45 on: August 06, 2007, 05:18:30 PM »
Poo-ey... replaced the diodes on the bad card and now it is getting juice but it induces a nasty noise into the entire system and doesn't pass audio.  Something is wrong... hopefully bad caps?
The other 7 channels are working great and sound sweet!  Miko, Joe has a new go-between kit where you can mount the input transformer directly on the card.  I wish he would've had those when I ordered my kits, but again, it took me so long to rack these things up...
gang of elk
« Reply #46 on: August 06, 2007, 11:13:44 PM »
sweet!!
rattleyour
« Reply #47 on: August 07, 2007, 12:28:07 PM »
That 8 pack of QE's is staggering... I LOVE my humble pair of them.
Enjoy!
CJ
« Reply #48 on: August 07, 2007, 06:19:54 PM »
hmmm, no Memorex tape on Miko's avatar, what up?
If I can't fix it, I can fix it so nobody else can!
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
b3groover
« Reply #49 on: August 07, 2007, 11:21:13 PM »
Well, right now it's a 7 pack because I have one card that isn't working.  I hope I can fix it.  I've had these cards for years and never tested them until the other night.  7 of them are exactly the same, the 8th one (the one that doesn't work) had different diodes on it and some handwriting on it.
SonsOfThunder
« Reply #50 on: August 07, 2007, 11:33:41 PM »
Well at least its not the other way 'round!
Seriously, laying out a good one and taking voltage measurements from it should help you find the fault(s) on the bad one, eh?
HTH!
Charlie
"The sow would rather have her ear than a purse." - PRR
b3groover
« Reply #51 on: August 10, 2007, 02:01:16 PM »
Yes, that's a good idea.  I just hope it's not the output transformer.
emrr
« Reply #52 on: August 16, 2007, 02:16:54 PM »
Ohm out the output and see; doubtful IMO.  Also see if you can get a current measurement on the individual module to compare.
I've got a similar 8 banger waiting to build, but with these two channel CA-727 cards.  They are same as the earlier AM-3 five transistor CA-127's, but two on a card and no attached output trans.  Here's an example of a pair I did FS, with Edcor outputs.   I've got just enough of some older Jensen outputs for my keepers.  Mine are a fairly rare variation that Ken Hirsch of Orphan Audio / Quad Eight Electronics LLC had to ID for me.
rattleyour
« Reply #53 on: August 16, 2007, 04:11:15 PM »
Hey Doug, where did you get those cool QE badges?
I saw them in some otehr pics you posted.
emrr
« Reply #54 on: August 16, 2007, 06:28:29 PM »
I made them.    Labels are all old style faux-decal stickers with laquer coating, ala antique WE, military, etc gear.
CJ
« Reply #55 on: August 29, 2007, 05:05:21 PM »
whats this?
is that the stock transformer?
emrr
« Reply #56 on: August 29, 2007, 05:47:47 PM »
That's the stock output transformer found on cards that use them.
CJ
« Reply #57 on: August 29, 2007, 06:06:48 PM »
i see.
i have a 1500,uf instead of 470.
is that an option?
hitchhiker
« Reply #58 on: August 29, 2007, 08:02:02 PM »
Hey CJ!
  1500 uf is the stock output on the CA-127. The next v is the CA-137 and it has the 470 uf.
Sure be cool to see one of these output transformers put through the paces.
Lance
CJ
« Reply #59 on: August 29, 2007, 08:29:12 PM »
thanks!
I SAW A 2200 UF ALSO.
Cj
