its a pain in the ass to get them out but a really secure way to get them in and have them stay there.
remove the four bolts in the transformer. Replace with a bolt about an inch or whatever longer. Drill four holes in your chasis to line up with the holes in the transformer. Slide new longer bolts through the chasis. Put a plastic (you may need to use a metal standoff for the one position with the ground trace) standoff on the bolt, 1/4" will probably do. Now mount the transformer and the pcb back onto the bolts and screw the nuts down on top of the transformer. thats the way I mount all that type of stuff horizontally. Its a bit of a production when you need to remove the amps to fix or swap components but its a great roadworthy solution, once you bolt it down, it aint going nowhere.
dave
dave
