dmlandrum
LD capsules - center-terminated vs. edge-terminated?
« on: June 18, 2004, 04:11:54 PM »
This question got asked (by someone else) in another thread, and it kinda got missed.
What are the differences in sonic quality between center-terminated and edge-terminated capsules?
The famous U47/67/87 family, as I understand it, uses a center-terminated capsule. I would think this would be responsible for its scooped midrange to a great degree. If this is true, that would mean I would want to avoid center-terminated designs in the digital age, due to their more hyped-up high end.
Right? Or am I way off?
Darren Landrum
Be comforted that in the face of all aridity and disillusionment
And despite the changing fortunes of time,
There is always a big future in computer maintenance.
tommytones
« Reply #1 on: June 18, 2004, 04:24:20 PM »
I wish I could answer... :?   I too am interested by this.  I saw your question in the other thread but as you said, it seems to have been overlooked.
ToM
He who asks is a fool for five minutes, but he who does not ask remains a fool forever.
Chinese Proverb
Marik
Re: LD capsules - center-terminated vs. edge-terminated?
« Reply #2 on: June 18, 2004, 04:25:55 PM »
Quote from: "Consul"
Consul,
Since in edge-terminated capsule there is no center support for the diaphragm, it usually has more extended both LF and HF range.
Samar Audio & Microphone Design
www.samaraudiodesign.com
The Art of Ribbon Microphones
dmlandrum
« Reply #3 on: June 18, 2004, 06:05:39 PM »
Quote from: "Marik"
So it's the exact opposite of what I said?
If I don't want a very bright microphone, which would I want to choose?
Thanks for the input!
Darren Landrum
Gus
« Reply #4 on: June 18, 2004, 06:15:17 PM »
That is a very hard  to answer question!
With the 67 and 87 ther is a feedback network that eqs high and low.
Then there is the eq caused by the grill design.  That is one of the reason I believe neumann protects the trademark on the 87,67,49 style grill.  I don't understand how it is a trademark.  IMO it should have been a design patent with a 17 year life.
Round shape grills have different eqs.
Then you have the capsule response
And then if it has a transformer you have the core type with it BH curves etc. and winding style.
I have installed the same  capsule in different grills, sound different.
Think of it like the capsule eq+grill eq+electronics eq and maybe transformer eq.
Then you have the two major designs one AKG uses and one Neumann uses. you could have a center akg and no center neumann IIUC
There are so may things going on I don't think it can be center or non center.
dmlandrum
« Reply #5 on: June 18, 2004, 06:25:16 PM »
Well, of course it all plays together, but surely the capsule termination is no minor issue. Center-terminating is essentially placing a damping mass in the center of the diaphragm, after all.
Darren Landrum
Gus
« Reply #6 on: June 18, 2004, 06:36:33 PM »
Yes! but the air mass is greater than the diaphragm mass >4times IIRC.
 What I am trying to say is that both styles of capsule can be adjusted.  And the two styles tend to be used in different shaped grills.
dmlandrum
« Reply #7 on: June 18, 2004, 06:39:07 PM »
So, if I choose to embark on the quest of making a G7 microphone, I need to choose what grill-shape I'll make before I get into which capsule design to use?
Yes, this line of questioning has a method to the madness. :green:
Darren Landrum
Gus
« Reply #8 on: June 18, 2004, 06:48:47 PM »
I don't know what to say I still have much to learn!
  Let me point out that some very nice microphones with both style capsules use round grills.  ELA M251 and the VM1
dmlandrum
« Reply #9 on: June 18, 2004, 06:50:29 PM »
Well, as I recall, Jakob's original G7 was a round grill with a CK12 capsule, which is the AKG edge-terminated, correct? I'm just wondering how to avoid making something that's super-bright.
Darren Landrum
dmlandrum
« Reply #10 on: June 18, 2004, 06:53:35 PM »
Yes, I know. I'm asking for the world. :green: I'm sorry...
I'm just a guy trying to learn stuff! :grin:
Darren Landrum
« Reply #11 on: June 18, 2004, 08:52:06 PM »
OK, here are some thoughts. The condenser is esentially a capacitor. It changes capacitance as acoustic vibrations make the diaphram move. The rest of the circuit is set up to sense these changes, anplify the signal and send it along it's way.
As long as the capsule is making these capacitive changes accurately in response to the acoustic signal, the edge vs center termination is probably the least of the factors affecting what sound you get. In the capsule, more important factors are:
   type of diaphram material.
   Placement of the little acoustic holes in the backplate.
    Capsule resonance chamber.
    etc, etc, etc
I'm sure the tremination makes some difference, but I think it is very small with respect to the overall performance of the microphone.
Last post January 20, 2005, 09:51:31 AM
by alk509
Last post February 17, 2009, 07:55:41 PM
by rodabod
Last post July 31, 2019, 05:19:17 PM
by kingkorg
Last post October 18, 2019, 07:16:58 PM
by midwayfair
