1176 question for expert
xela_92
France
Dear all,
I have to repair a 1176 Urei.
It is a front pannel blue stripe but the circuit is a "D" type with the 2N3053 class A transistor output.
There is inside a square black circuit, like a 2520 API but with different pin out, nothing written on it, there is a small rotary control, and it is bigger.
It is close to the input transformer.
What is this ?
Did you know this ?
Do you have a schematic ?
Olivier Bolling
Maybe this one should be for the Drawing Board, but what's the theory behind the addition of the LN (Low Noise, right?) mod?
Frank
I have a basket case Blue Stripe and the module is disconnected. If yours is hooked up, can you tell me which wire from the module goes where?
Find the URIE 1176 Blue schematic here:
http://www.one-electron.com/FC_ProAudio.html
"The Blob" modification as I have it is the stuff within the dotted line on this picture:
Keith
