Always measure resistor with DMM before populating with alligator clips to the resistor leads. Don't touch leads with your fingers while measuring because your body can add resistance. Resistance will change in circuit most of the time meaning trying to measure once soldered to board could give you inaccurate reading. One would have to lift a leg of the resistor to get accurate reading in circuit. Not ideal. Just be familiar with color code you should be fine. https://eepower.com/resistor-guide/resistor-standards-and-codes/resistor-color-code/# Carbon Composition 5% at best.
I like to use a multifunction tester. I find it much quicker and easier than a DMM for testing parts. They are all over Ebay, Amazon and Ali express. That is a US link but you will easily get one in Germany.
https://www.amazon.com/Treedix-Tran...DAifQ==&sprefix=TC1+component+,aps,143&sr=8-2
