This question popped into my noggin' the other day (I don't recall why)... Would anything disasterous happen if the "positive" and "negative", or pin 2 and 3, in a balanced line were to have several dBV of difference?
For instance if a mic pre or line amp output is balanced, and for some strange reason there's a rather significant difference between the 2 and 3 pin signal levels (the 3 which will usually be grounded at the input of the next stage), will this provoke some phenomenological audio beast to be awakened?
