L´Andratté
Re: Feeler: Classic Solo
« Reply #280 on: October 13, 2019, 01:09:31 PM »
Hello Ian!
Hope this is an ok thread for my questions-
After all I feel ready to build some tube stuff and I want to build a pair of your Classic tube pre design.
I don´t have the pcb but want to experiment with p-t-p and eyelet etc. anyway, I just chose the design because it seems to achieve what I want (clean and big sound ;))
and is so exceptionally well documented! (other than Pultec MB1, which I first planned, maybe later)
I want to build the lo hum ver, with an external power supply, now finally my questions ::)
*Would you agree that HT 250 supply should completly go into the external box
with HT DC in the umbilical cord (I think so)?
*If so, what kind of smoothing/bypassing should happen in the actual audio unit?
*Heater supply AC (after elevation divider) through the umbilical directly to filaments?
*Would it be a bad idea to use an unvented (Hammond) steel chassis of
30cm*20cm*5cm (ca. 11.8"*7.8"*1.9") for two (or even four?) of the 6922 inside?
I´m shure I could cram it all inside but afraid it get´s too hot,
although it would be very convenient for me...
Sorry if this is cold coffee for you, I DID use the search function but wasn´t able to come
up with the answers for these, although I bet you have already covered this stuff somewhere!
And hats off to your work btw. your grounding paper is one of my go-to documents!
« Last Edit: October 13, 2019, 01:18:00 PM by L´Andratté »
"Why not get an assistant to work the faders? Real vintage! And maybe cheaper... ;)"
« Reply #281 on: October 14, 2019, 06:24:31 PM »
Hello Ian!
*Would you agree that HT 250 supply should completely go into the external box
Yes
For a single mic pre you probably don't need any but it would not hurt to include a 100nF 400V film capacitor ascross the HT supply in the preamp box
For the ultimate in low noise/hum I would recommend dc heaters combined with wiring the heaters of the pair of 6922 tubes in series and running them off 12V
Depends. If you use the mu follower topology using 6922 tubes then the dissipation is at its highest. This is because each 6922 mu follower has to be run at about 10mA HT current to keep distortion down when driving a 600 ohm load. HT of 300V and current of 10mA means total plate dissipation is 3 watts per stage so 6 watts total. Heaters of 2 stages consume 12V at 0.3A for another 3.6W. So the two stages together create 9.6  watts of heat. Your box has 3 litres of air in it. So you want to create say 10  or or watts of heat in a 3 litre space. My gut tells me this should not be a problem.
To put this in perspective, in the EZTubeMixer project I ran a pair of 6922 tubes and a 12AX7 inside a totally enclosed box that was 17cm by 11cm by 7cm which is 1.122 litres.  The 6922 tubes are only running at 6mA because the topology is different but this is more than compensated for by the heater consumption of the 12AX7. Total heater dissipation is 12V x 0.45A = 5.4W. HT dissipation is 300V x 13mA = 3.9w. Total is therefore 9.3W. I have run these enclosures for many hours and the front panel only gets slightly warm. So I would say you box should be fine.
L´Andratté
« Reply #282 on: October 15, 2019, 06:51:41 AM »
Thank you very much!
funkymonksf
« Reply #283 on: March 27, 2020, 02:57:21 PM »
Hi Ian,
Is it required/critical to use 2x 33k resistors rather 1x 68k resistor for R23?
« Reply #284 on: March 27, 2020, 07:40:31 PM »
Hi Ian,
Not required but definitely recommended. The 2 x 33K plus 22K  equals 88K so 25% of the HT is across the 22K and hence 75% is across the 66K. If the HT volts is 300V then the dissipation in the 66K is nearly 770mW I use 2 x 33K so the power is split equally between them which is just under 400mW each. So it is fine to use a 2W resistor for each one. If you want to use a single 68K then is really needs to be rated at 5W and given plenty of space to lose its heat.
funkymonksf
« Reply #285 on: March 27, 2020, 07:47:56 PM »
Hi Ian,
Thank you! That may have saved me a resistor burnout.
mrclunk
« Reply #286 on: August 21, 2020, 11:16:59 AM »
Hi ian,
considering building one of these. Your design, docs and info are amazing, thank you!
I'd really like a few tube channels to pad and overdrive for some subtle distortion.
I have a question regarding heaters.
If i was to use a small 12VDC SMPS for the heaters, do still connect the marked '12VAC' heat elevation points, to the 12VD supply?
I saw your post about small HT transformers earlier in the week which makes this more viable for me.
thanks
« Reply #287 on: August 21, 2020, 05:00:20 PM »
thanks
Yes you do. The heater elevation serves two purposes. First it raises the dc level of the heaters so that the Vhk spec of the tubes is not violated. Second, via the included electrolytic capacitor, it connects the heaters at ac to analogue 0V. Both of these apply whether you have ac or dc heaters.
myers1st
« Reply #288 on: October 21, 2020, 10:59:30 AM »
Hi all, I just finished up my Classic Duo with Ian's Helios 69 eq added in, everything worked together well and it sounds great!  I had fun with my first faceplate design, Frank from frontpanels.de made it for me, really happy with it.  I did one mu follower and one SRPP just to do some comparisons before I decide which I like better and match them.  I'm still playing with them, but will report with my take on the difference.
I do have a little hum in the channel closer to the toroidal tx.  I might try to rearrange the boards a bit to fix, but the don-audio MILA is too big to go vertical in 2U unfortunately.
I've got some Helios boards left over if anyone wants any.
« Reply #289 on: October 21, 2020, 03:38:03 PM »
Looking good. Can I send that photo to my friend Pierre who hosts a gallery of DIY projects built from my designs?
Also, it it may be possible that the bass inductor in the Helios EQ is picking up hum from the mains transformer. Might be worth experimenting with some shielding.
myers1st
« Reply #290 on: October 22, 2020, 05:18:49 AM »
Yeah, of course, I'll try and get some better pics to email you too.  Thanks again Ian, this was a really fun project for me.  And thanks for the tip on the inductor, I was mainly trying to keep it away from the transformers and tubes.  I'll try it.
I did have a question about the zobel network, I installed 150k for Rz and I just shorted Cz, should there be a cap there?  I have the Sowter input tx.
« Reply #291 on: October 22, 2020, 12:22:30 PM »
For Sowtrer, Jensen and Cinemag mic input transformers, 150K is all you need. Check the manufacturers data sheet if you use any other type.
