Nice docs as always! Very thorough. I like all the options you built into this. HPF and continuous input pad are great. The SW PCB is really nice. Its going to be a fun build. A few questions...
1. To build as a pre with DI the DI input would go into J5 and J4 would be shorted? Or would it be plugged into J4 like the DI box? Or either? On the PCB it looks like J5 is going into the TX.
If you want a mic pre that also has a DI input you wire the DI to J4 just like the DI box. The mic input goes into J1 as usual. The transforme routput from J5 then needs to be wired to the DI input socket. You need to arrange the socket contacts to connect the transformer through when nothing is plugged into the DI input and to disonnect it ehn the DI is plugged in. I'll add a schematic of this to the docs.
2. Can the "Drive" pot be connected to J4 even if I am building the pre just to get some dirty drive when required?
In the mic pre, the transformer output goes straight into the tube input - it is as if the drive control was at 100% all the time. Drive is adjusted by the pad
before the mic input transformer. The variable pad is effectively your drive control for the mic pre. When you drive the first stage hard, its output can be very large - as much as +30dBu. The output stage has about 22dBu of gain so, for a nominal +4dBu final output, the input to the last stage needs to be about -18dBu. This means the gain pot needs to drop +30dBu down to -18dBu, a total of 48dB. Under these circumstances, the gain pot ends up being very nearly turned completely off and adjustment is very touchy. In a previous deign, to combat this problem, I added an extra switched 20dB pad just before the gain control so the pot can be used near the middle of its range. This makes no difference to the amount of drive you get. It just manages the downstream gain. I'll add this to the docs as well.
3. If I wanted to add the REDD EQ or any of your other EQs would it be before the 10k gain pot like the HPF setup?
You should add these EQs
after the 10K pot. You can still have the HPF before the pot as well if you wish. I'll add this to the docs as well.
4. I know this will mess with the impedance but is it possible to add an output attenuator after the output transformer in the style of the SR124 or in the style of the attached image?
This question is more about wanting to drive the hell of of this preamp if need be and get a little tube dirt for example on a DI bass. I know that this is a clean tube pre design and that you have taken measures to get a high gain, clean sound but options are always good. I guess if a "Drive" pot is possible than this question is moot anyways.
Yes you can add an output attenuator after the output transformer which will allow you to drive the second stage harder as well. You can make a simple one with a pot and a couple of resistors:
https://drive.google.com/file/d/0B_n67A1hN3qtVTVZaUR3blFMYWs/view?usp=sharing5. If I were to build this in a dual configuration is there a simple way to attach power, 48v and heater from 1 board to the other so as not to build 2 power supplies?
Heaters are easy. They are AC so just parallel up the connection from the mains transformer. The phantom power supply should easily supply a couple of inputs so just build one of them and wire it to both mic inputs. The problem is the HT because it also creates the heater elevation voltage. The HT supply is designed to run one channel alone, so as well as using lower value smoothing caps I removed one stage of smoothing, to save both space and money. Ideally you want one HT supply to power two boards. To do this just reduce the value of R21 and R22 to 470 ohms. Connect the HT from the junction of R22/R23 on one board to the same point on the other. Link the AGNDs of the two boards together and connect the AGND of the board with the power supply to the chassis bolt. I'll probably add this to the docs too!!
6. Again messing with impedance but if a meter is required it would go after the output TX?
After the TX, yes
I really like stepped gain pots so I would probably build a stepped 10k switch for the gain. Something like http://diy-tubes.com/gain-switch-kit.html or P2P
Alain
Stepped gain controls are fine. The stepped pot you linked to is not a stepped pot - it is a stepped series resistor. However, you can probably solder an additional wire to the PCB to make it into a proper pot.
