Zjcc56
    Vermilion, Ohio.... Near Sandusky Yes there's an amusement park there
Drip Sta-level documentation
« on: December 15, 2015, 12:19:36 PM »
hello all.
So I recently bought a drip sta-level pcb off the black market and before I had a chance to get all the documentation off the drip site, it was taken down and is nowhere to be found. I emailed drip about a month (or two?) ago and was told it would be put up soon. Alas it is still not up. I have emailed again last week and no response so instead of harassing someone who is probably super busy already, I turn to you! I have the schematic from somewhere else around here but I'm looking for the bom and the release mod and anything else for both the big version and the micro version, I vaguely remember both having valuable information to build it
Any help would be great!
Thanks!!
There are known unknowns,
and unknown unknowns...
Re: Drip Sta-level documentation
« Reply #1 on: December 16, 2015, 09:44:25 AM »
Zjcc56
« Reply #2 on: December 16, 2015, 11:26:13 AM »
Awesome! Thanks a lot  :D
now i need to figure out how to adjust the balance pot (r41)
any suggestions?
« Reply #3 on: December 16, 2015, 04:11:51 PM »
any suggestions?
 As you can see it uses between pins 8 of 6V6 tubes. This pot control an equal voltage on both cathodes of tubes. So measure voltage and adjust pot until you get voltage as close to each others as possible.
Brizco
« Reply #4 on: December 18, 2015, 10:00:32 AM »
Thanks for the Documentation!!!!
I mailed Drip for the Docs, but no help received...
groupdiy rocks!
Rlucas41
« Reply #5 on: February 12, 2020, 11:26:37 PM »
Hello, I need Drp Sta level docs too... can some repost an active link or pm me with it?
Thank y’all!
scott2000
« Reply #6 on: February 13, 2020, 07:06:55 AM »
The dual sta docs are out there as well as the micro.... I can't tell if there were any docs for the STA pcb  that came after the micro but, there is a bom... Hopefully someone has something for you....here's a link to the bom (which is pretty detailed with schematics and explanations ) for the sta pcb...and some other other stuff from that point in time...
https://web.archive.org/web/20131022205621/http://dripelectronics.com/index.php?option=com_content&view=article&id=30&Itemid=57
« Reply #7 on: March 05, 2020, 10:21:57 PM »
Here is the Guide and BOM. I had to separate it into two parts (due to file size).
Attached here is Part 1.
« Reply #8 on: March 05, 2020, 10:22:37 PM »
Here is Part 2.
scott2000
« Reply #9 on: March 06, 2020, 03:30:37 AM »
Nice! Thanks...
I wonder if Gregory would have an issue with having a dedicated Drip technical docs section....
Seems like it would be helpful to his user base.....
Rob Flinn
« Reply #10 on: March 06, 2020, 07:19:36 AM »
Nice! Thanks...
He shouldn't do because he supplies little to no support himself.
regards Rob
« Reply #11 on: March 07, 2020, 09:33:54 AM »
I also have the manuals for the 175 (Ver 1 and 2) and the 660. I noticed these contained some building tips and original circuit references not found in some of the other manuals.
Caveat: I don't know how much he did or didn't provide support.
But at some point, I assumed the extremely-detailed drawings found in these may be one of the reasons why others have said he didn't provide much support. So I referred to these often.
The file sizes are too large to attach here: 175 ver1 is 8.12 MB, and the 660 is 5.48 MB.
