Re: [BUILD] NU FEDERAL AM-864 PCB OFFICIAL BUILD & HELP THREAD
« Reply #100 on: October 11, 2017, 10:52:16 AM »
 :o woww ! crazy
Eliani
« Reply #101 on: October 11, 2017, 02:35:55 PM »
Yep, you've got to love that!!
so new tubes in mine! I was able to find a couple real close to each other, now the voltages are cool!
Next up is metering, I've got a 1mA meter. But the dial wil not go upto the max value, and with extreme settings the dial is halfway the scale... not usable I would say...
What do you guys sugest?
"Iron Projects" at Eli-Audio.com
djfatum
« Reply #102 on: October 11, 2017, 05:40:11 PM »
The VU must have 200 micro amperes (1 milli amper too much)
Eliani
« Reply #103 on: October 12, 2017, 01:34:58 AM »
Cool, that's what I thought
Eliani
« Reply #104 on: October 12, 2017, 11:27:02 AM »
This might be better in another thread, but what CNC are you using? Are you just engraving anodized aluminum? Love the look of your panel. :)
I’ve got a BZT PFE1000PX, and Yes anodised aluminium. And thank you!
Eliani
« Reply #105 on: October 12, 2017, 12:31:46 PM »
Could you tell me what meters you bought and where you got them? I'm having trouble finding them.
« Reply #106 on: October 14, 2017, 05:13:21 AM »
Don audio  sells them in 200 micro amperes now...
rob_gould
« Reply #107 on: October 14, 2017, 05:34:46 AM »
Not to brag but i'm kind of proud of this build!
At least of how it looks because wiring could have been a bit cleaner, but I'm sure I'll get it next time. I'm waiting for new 6BA6/EF93 tubes to arrive, I've bought like 10 and hope to good pair out of them. I'm not totally aware of how one would match tubes, or if I even need to, but I'm guessing it wouldn't hurt as I can't seem to get C and B to the same voltage! This might explain that the input get's distorted when cranking the input?
I've yet to do the threshold/ratio range reduction mods
Really great job - you should be proud!
I've been a bit out the DIY loop for a while but seeing your project had inspired me to get back to a couple of half-finished projects of my own...
Studio furniture, modular synth cases and more...
www.gouldcaseworks.nl
Eliani
« Reply #108 on: October 14, 2017, 01:29:57 PM »
Yeah, I tend to lose interest in certain projects after a while too, but most of the time it's lack of time or funding!
By the way, about the 200uA DC meters, Aaron from Don-Audio let me know he's doing a run for them, now available in his store, although they will not be available for another 3 to 4 weeks. So I bought another Weston 2521 meter, but instead of the 1mA I found a 200uA version. And I bought a bunch of strange 200uA meters just for future projects.
I ordered 4 more PCB's from Zayance for a single control stereo version and one with a mono switch and dual controls... looking forward to that, because I just spent over €1000 for all the parts!
« Reply #109 on: October 25, 2017, 04:24:15 PM »
Hi everybody,
Here, finally I finished the unit.
not without trouble with my beginner errors when buying audio transformers without CT eg: thank you bernbrue for your information that allowed me to finish this jewelry without too much trouble.
indeed I say: "without much" because during my measurements I fall on these values, and this as well on the left unit as on the right unit:
B + = 230 V
A = 14.46V
B = 224 V
C = 227 V
D = 173 V
E = 1.09V
F = 1.09V
G = 230 V
H = Over Load on the multimeter.
When I turn on the beast, the two hands go up to +2 dB then go down slightly, tremble lightly then come to fix on -3db is in the center of the VU meter. knowing that I was mistaken for sensibility of Vu meter as seen before with Eliani.
If you have a small idea of what might possibly be there. I take.
« Last Edit: October 25, 2017, 04:35:07 PM by jefflehiress »
bernbrue
« Reply #110 on: October 25, 2017, 04:35:26 PM »
Either you've got a bad output tube (12AX7) or your output transformer is not wired correctly. You should have the same voltage as on G.
Bernd
« Reply #111 on: October 25, 2017, 04:43:34 PM »
Bernd
I bought a pair of 5751 RCA Jan NOS. I hope these are not the tubes: D
I will test that.
bernbrue
« Reply #112 on: October 25, 2017, 04:45:39 PM »
Post some pictures of your build. Makes troubleshooting easier.
Bernd
« Reply #113 on: October 25, 2017, 05:14:47 PM »
« Last Edit: October 26, 2017, 05:26:02 PM by jefflehiress »
« Reply #114 on: October 25, 2017, 05:26:26 PM »
ok, so I just changed by 12AX7B China to test something else and the values are:
A = 14.30 V
B = 223 V
C = 224 V
D = 173 V
E = 315V
F = 357V
G = 230 V
H = 230 V
either, no more coherence with the previous results.
I also have the hands that are at the bottom right of the Vu meter and bouncing in rhythm ...
bernbrue
« Reply #115 on: October 25, 2017, 05:26:54 PM »
Very nice build. How have you connected the meter trimpots? Try to measure voltage on H once again. There must be some voltage.
Bernd
bernbrue
« Reply #116 on: October 25, 2017, 05:32:02 PM »
E and F are not measured correctly.
Bernd
« Reply #117 on: October 25, 2017, 05:35:51 PM »
Bernd
thank you ! trimmers pots are wired on CW and C.
« Reply #118 on: October 25, 2017, 05:49:02 PM »
Bernd
ok, sorry E = 315 mV
                     F = 330 mV
you think that the bouncing needle is due to bad wiring trim pots?
When I turn the threshold to the max the needle does not bounce but is fixed a little lower.
« Last Edit: October 25, 2017, 06:14:13 PM by jefflehiress »
bernbrue
« Reply #119 on: October 26, 2017, 04:02:38 PM »
Watch my video.  The meter needs to be retrimmed quite often. Did you tame the pots as suggested in the first post?
https://www.youtube.com/watch?v=0eJVCCYApOw
Very nice unit. Be proud of yourself !
Bernd
Last post April 08, 2006, 07:18:56 AM
by gary o
Last post March 16, 2007, 04:00:06 PM
by cannikin
Last post June 29, 2010, 05:22:14 PM
by fazer
Last post November 09, 2018, 09:56:07 PM
by mkiijam
