sonolink
Hello everybody
I'm building a tube preamp in a pedal. It has a Master Output pot. It's designed to run it as a pre in an amp's return FX loop.
I'd like to be able to place it in front of the amp as a stomp box but it doesn't sound very good.
Asking the designer he tells me: "If using this effect purely as a stomp box and not as a preamp, then you may wish to substitute the A1M master pot for an A100K. It’ll make it a little less in your face. Or you could just turn it down".
I guess I could, but isn't this possible using the same pot and a switch to flip between "modes"?
Thanks a lot for your help
Sono
Sono
