Amp FX Loop
sonolink
London-Madrid
I built an 18w tube amp for a friend some time ago. Now he would like me to implement an FX loop to be able to use the power stage with other preamps.
I have attached the original schem with the mod drawn in red (between the pots and C9). Would that work?
Thanks for your time and help :)
Sono
https://ibb.co/44SHv0t
What was the 470K in the PI inverter attached to exactly? Maybe you should post the original unmodified schem.
Note that tapping into the vol control will make the send output impedance quite high potentially. And the level will be too high for pedals.
But if you're just using the return, it might work ok.
