Alexandru marian
- Joined
- Oct 13, 2014
- Messages
- 127
My G9 uses Lundahl 1530 for input, 1:7, 200:10k
I was wondering about possible "better" options. More gain is not really needed, less is ok.
First I looked for higher level handling / lower distortion. This lead to Jensen 13k7, Lundahl 1538XL and Sowter 9045. These are 150ohm (Jensen) or 200.
It then occured to me that my mics are on the high side: 200ohm for the DPA 4011, and (I think) 660 for the G7 mics. In these I have used 16k:660 Sowter 9995 transformers.
Since ideally the preamp input impedance should be several times higher than the mic output (right?) it seems I might need to look at other options too. Lundahl 7905?
What am I missing when the mic impedance is higher than the pre imp? In real my G7 has plenty of bass and is quite loud hooked to the G9. If anything, I would like more treble.
Thanks...
Thanks...
