Alexandru marian
- Joined
- Oct 13, 2014
- Messages
- 127
My recording setup is: 200 and 600ohm microphones, 1:7 (200:10k) input transformer hooked to a tube preamp (GYraf g9, 1M grid leak)
Testing with a 1:2 (600:2400) input trafo, I have the feeling the 600ohm mic has a nicer fuller tone. Of course 1:2 doesn't have sufficient gain so I am thinking about getting a higher ratio 600 ohm primary.
I know these impedances are relative and what matters first is the ratio, but I also got the impression producers mention impedance ratios based on inductances, with chunkier units better suited for higher imp?
Question is, if I fit the pre with say a 1:4 or 1:8 600ohm transf, would that present a loading (or any other theoretical) problem for the 200ohm mics?
