skal1
hi
can you mount tube sockets on G1O FR4 Board, and what thick should i be using .
cheers
skal
cheers
skal
It depends on the heat. For small tubes such as 12AX7 or EF86, no problem, but power tubes, you need to make sure there's proper ventilation. I wouldn't mount 6L6's, even 6V6's on a PCB. I've done it with EL84's, with good results.skal1 said:hi
cheers
skal
