beatnik
IPC AM-1065 transformers = UTC ?
« on: March 17, 2017, 08:05:28 AM »
I have been looking at a pair of IPC AM-1065 tube preamp modules
The audio transformers are stamped with FP-3427 and FP-3428
Searched on the forum and someone posted pictures of a similar model by IPC with UTC HA-100x and A-25 transformers
I was wondering if you have any information on these FP- transformers ?
keeeth
Re: IPC AM-1065 transformers = UTC ?
« Reply #1 on: July 25, 2020, 07:29:02 AM »
Bump
I keep seeing these transformers
Does anyone have any info on them?
« Reply #2 on: July 25, 2020, 08:40:22 AM »
Both types were used, so functionally equivalent. What else is needed?
keeeth
« Reply #3 on: July 25, 2020, 09:22:35 AM »
I was hoping for a pinout and some information on the windings if possible, the ones I've seen don't have anything on them
Also, just so I'm clear, I have the other IPC preamps mentioned here but one of my Ha-100x is damaged
Are you saying the FP-3427/8's are a suitable replacement?
rackmonkey
« Reply #4 on: July 25, 2020, 03:33:18 PM »
Most of the FP-3427s I’ve seen are made by Freed, not UTC.  I have had IPC products in my saved searches on evilbay for a few years, and have seen a lot come through over that time.
if the top of the transformer case looks somewhat like a UTC A-series transformer, then UTC probably made them. The ones with a circular groove on the top of the case are made by Freed.
Functionally the same, but if you’re specifically after what you suspect to be an OEM labeled HA-100x. then note the difference.
Whether you think you can or you think you can't, you're probably right.
keeeth
« Reply #5 on: July 25, 2020, 05:35:52 PM »
Ok thanks for the info
Ultimately I just want it to sound the same, would that be the case?
rackmonkey
« Reply #6 on: July 26, 2020, 01:53:30 AM »
I have no experience with either IPC transformer, so I can't tell you for certain that they sound the same. They were made to the same specification, but there are often differences between similarly spec'ed transformers made by different companies. I can tell you that I've used off-the-shelf PGA, PMA and QGA series Freed transformers in several units, and they sound very good.
Here's a Freed catalog from 1966. Though less well-known  than UTC, Freed made some very good broadcast quality units.
https://drive.google.com/file/d/1kX_xuYNaw_IDw9yM7nPez_TQNg8YX5WV/view?usp=sharing
keeeth
« Reply #7 on: July 26, 2020, 09:21:43 AM »
Ah cool I'll have a read through, thanks
When I say the same, sound I just mean in general
So for instance, could the difference between these Freeds and the UTC be likened to the difference between Marinair/st Ives/Carnhill in a Neve?
In that they were commissioned by Neve to make transformer to a spec and the differences end up being ultimately subjective
Do you have a pinout for these? Or do you know what it where?
The HA-100x has a lot more terminals than the FR 3247 I'm looking at and I'm not sure which ones the windings are on
